CPU-Z reporting 2 V on R5 3600! and running at 70-80 on idle!
CPU is running very hot all the time!
While idling it is at 2V according to CPU-Z and at 70-80° C! Also, CPU-Z and RYZEN MASTER are reporting different Voltages? RYZEN master says its constantly pinned at 1,325?
When booting the system, it has died twice, and runs at up to 99° C?! It sounds absolutely absurd? Also, when stress testing with the RYZEN MASTER it only came up to 90° C which I find even stranger?
What could be the problem? I have tried:
updating BIOS and drivers, reseating the cooler. Also, the PC.
r/overclocking - CPU-Z reporting 2 V on R5 3600!
I would only trust hwinfo64 and ryzen master for voltage and temps for ryzen.
Clear the cmos and then monitor temps and voltage with ryzen master or / and hwinfo64. ( Not at the same time.).
Phone: Pixel 3a (Purple-ish).
Build Log:
Your CPU would be long dead if it really was running at 2V.
Update your BIOS and chipset drivers, use HWiNFO64 or Ryzen Master to monitor temps/voltages, use the Balanced power plan if you aren't already, and if the Windows install you're running is from a previous build then reinstall the OS.
Also, replace your power supply immediately because the orange label Corsair VS are a legit fire hazard.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
if its turning off straightaway thats thermal cut off, reseat your cpu and reapply TIM then make sure your cooler is seated correctley and plugged into the correct header on motherboard.
as for the voltage anomalies as the user above stated only trust hwinfo64 or ryzen master for telemetery
what do you mean by clear cmos? I installed hsinfo and it is reporting Voltages at under 1,325 as it should. But i noticed the CPU has athermal limit at 115? sent all info belowimage.thumb.png.9b57d9b82c3b56fdf16f50b8f4aec6ef.png
This looks like an older version of Ryzen Master.
Download / Update / install to the latest version first.
What motherboard (make and model) are you using with that Ryzen 3600?
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
I have the latest drivers from www.asus.com/us/Motherboards/ROG-STRIX-B350-F-GAMING/HelpDesk_Download/. I use a higher Fan curve value than before with 3600.
If nothing works on this thread I'll reinstall windows.
Thats exacly what happened I sadly beleive. TIM is thermal compund? Ill try that tomnorrow. I curently only lifted the cooler and put it back to place
this one. www.asus.com/us/Motherboards/ROG-STRIX-B350-F-GAMING/HelpDesk_Download/. All driovers installed including the bios via EZ flash in bios tools.
dont be sad lol its a safety feature to allow diagnosis, if it didnt shut off you would be pricing new parts right now. Yes TIM is thermal paste (Thermal Interface Material).
Good luck :)
Good luck :)
Haha, I thought it was bad enough that it reched the limit! Thank you for your help.
Yes i installed it like 10 minutes ago. Thats the one in my photos. It was in the basic view
until you reseat the cpu please stop running the machine, you may be damaging components
After setting and using chrome with 20 tabs it runs at 60. Is this normal and the problem was maybe only bad thermal sensor programs that I used (old CPUZ and Openhardware). Although, the fans are quite loud. Noticeble from like 10 meters w/o side panel. image.png.9fc507fcec6c52e5c40f6b3e7b493bca.png
60c is fine, maybe a tad higher than I would personally accept but well in acceptable range. if the fans are so loud then they are running at 100%, set up a fan curve to lower acoustics
The stock fan on the Ryzen 3600 can be loud.
They did change the fan on the stock cooler(s), compared to the Ryzen 2000-series (e.g. 2600 / 2700).
That said, it should keep the temperatures within safe levels (e.g. should not thermal throttle like Intel's stock coolers on higher core count CPUs).
Confirm that the BIOS you tried to flash onto the board ACTUALLY successfully got flashed.
When you used EZ Flash to update the BIOS, did you use the USB stick method, or the browse online menthod?
Physical BIOS file on a USB stick method is more reliable IMO, with less chance of errors and unsuccessful flashes.
AMD Ryzen Rig
  • AMD R7-5800X
"The stock fan on the Ryzen 3600 can be loud." That's probably it then. Thank you.
I used the USB stick version to install as I always do. I run my PC with WIFI so it wasn't really an option lol.
One of my friends swapped the stock cooler on their Ryzen 3000-series for a Arctic Freezer 34 eSports DUO, and he said the change was MORE than night and day difference.
Temperatures were also better when idle, and quite significant when under load / stress (e.g. gaming).
Another friend of mine is reusing a Noctua NH-U12S from their socket AM3+ AMD FX-8320 system, and quite happy with that too.
Newest revised version of this cooler is the NH-U12A, in case you are wondering...
AMD Ryzen Rig
  • AMD R7-5800X
The CPUz version you're using is pre ryzen 3000 support. this is known behavior. update program to current version
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Ah right, proper Ryzen 3000 support was added in 1.89+
AMD Ryzen Rig
  • AMD R7-5800X
Just checked and the Arctic Freezer 34 eSports DUO is actually the most viewed CPU cooler in sweden lol. So it is pretty quiet? I will not overclock but want it to be quiter than stock.
It is fairly quiet, and performs quite well too.
I think Arctic did a REALLY good job designing the cooler, and the P12 fans they included.
AMD Ryzen Rig
  • AMD R7-5800X
I have a Ryzen 5 3600 and use the AF 33 eSports. Its excellent imo. Brought temps down from the stock cooler by quite a few degrees - never goes over 60c even under load (unless running a bench but then it goes no higher than 80c) and it's usually around the 40-45c mark for me). Very good for the price i think.
