HELP i need to know if my pc is bottlenecked
Jessy20071
Go to solution Solved by svmlegacy,
1 minute ago, Jessy20071 said:
Hi fellow pc enthusiasts
my question is is my pc bottle necked
specs:
amd phenom 2 x4 955 (normal edition)
Gtx 1050ti 4gb
16gb ddr3 1600 memory
550 watt power supply
1 ssd
and 1 hdd
Hi, welcome to the forum.
Every system will have a bottleneck somewhere, depending on the task at hand. This is what limits FPS.
For an average gaming load, we need to know the approximate age of the games (specific games would be even better!), resolution, and refresh rate, and the settings you want to play at.
You can also check this yourself by logging using a software like HWiNFO:
  • High CPU utilization, low GPU utilization: CPU is holding the system.
  • Equal, high utilization: System is balanced, and working hard.
  • Low CPU utilization, High GPU utilization: GPU is holding the system.
  • Both low, it gets complicated. It could be:
    • Memory is full, and swapping to disk is holding it
    • Game is only single threaded, look for high CPU core utilizations, but low overall usage
    • Game engine is unoptimized, and cannot use the hardware effectively at your settings
    • etc, etc.
specs:
Gtx 1050ti 4gb
1 ssd
and 1 hdd
Depends on the game and performance target. Anyone who says simply "yes" or "no" without knowing is not quite right.
Primary PC:
Bottle-necked for specifically what? Software and games will each use your hardware in different ways.
Simple answer is no. Or better yet, don't worry about it.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
specs:
Gtx 1050ti 4gb
1 ssd
and 1 hdd
    • etc, etc.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
is use my pc to game like euro truck simulator 2 and dead by daylight and csgo
