Has LTT or anyone ever tried to chill the airflow of a fan?
nobodyshome
Has there ever been a video from LTT or has anyone here tried cooling the air before/after it goes through a fan attached to a heat sink? If so did it have a any impact?
If not, do you think it would have any effect or cause any issues? I'd imagine condensation/blowing water droplets all around your PC could be a huge issue aha
Basic physics apply there, not sure what exactly is your question is. Lower the temperature air fan pushing through fins, lower the temps.
Just interested if anyone has tried it and what the results/pitfalls are.
would be about the same as directly pumping Air Conditioner air through it.. Either it works, or you will end up with condensation if you drop the temps to low.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
I do it every day when I turn on my air conditioner.
CPU AMD 3700x  Mobo MSI Gaming Edge X570 WiFi  RAM 16 GB Hynix ADie @3800Mhz  GPU EVGA RTX2070S XC ULTRA  Case Fractal Meshify-C  Storage Corsair Force PCIE4 NVME 1TB + Crucial MX500 2TB  PSU Seasonic Focus Gx 650 !RMA'ing! - Thermaltake Smart 600w (TEMP)  Cooling Noctua NH-U12A  Keyboard Logitech G915  Mouse Logitech G PRO Wireless Sound Corsair HS60  OS Win 10
