Difference between H series and B series
39 minutes ago, SooWhat said:I meant with a higher end GPU so the GPU wouldn't bottleneck the CPU's (I checked multiple sources)
so what GPU did you check with? Dont tell me you just quote their conclusions
39 minutes ago, SooWhat said:What if I DON'T have unlimited GPU power that I wont be upgrading any time soon?
How long do you want this system to last (i.e. operable) and stay relevant (i.e. fast enough)?
QuoteAlso I initially asked about mobos. IF I were to buy the i3 10100, what would be the optimal mobo?
H410 and B460 only differ in feature set, which depends on what you need and want (also different boards carrying the same chipset vary on stuff they carry) so they are listed clear on webpages, largely subjective and not much I could add to it. They all have enough power delivery for something like a locked i3.
