Posted July 8, 2020 So my specs are as follows CPU: AMD Ryzen 1600x GPU:RTX 2070 SSD:Kingston A400 240gb (connected to asata; wouldnt show up otherwise when the m.2 is connected)- This is my primary boot drive HDD: Toshiba 1gb (also connected to asata) I put in a m.2 (Mx500 500gb) as my primary boot drive was running out of space and i wanted to migrate it, it is connected to pciex1_2 and will not show up on the bios or windows (I do eventually want to migrate my ssd onto the m.2) I had updated my bios to the latest version to which ive read can cause some issues, though i'm not sure. Thank you. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 n/m EDIT: Have you got any of the S-ATA ports populated? If so, which ones? I frequently edit any posts you may quote; please check for anything I 'may' have added. Did you test boot it, before you built in into the case? WHY NOT...?! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 7 minutes ago, Youngsinarta said: I put in a m.2 (Mx500 500gb) as my primary boot drive was running out of space and i wanted to migrate it, it is connected to pciex1_2 and will not show up on the bios PCIEx1_2? It should be connected to M2A or M2B. It won't work on M2B though, so you need to have it connected to M2A. "We're all in this together, might as well be friends" Tom, Toonami. mini eLiXiVy: my open source 65% mechanical PCB, a build log, PCB anatomy and discussing open source licenses: https://linustechtips.com/topic/1366493-elixivy-a-65-mechanical-keyboard-build-log-pcb-anatomy-and-how-i-open-sourced-this-project/ mini_cardboard: a 4% keyboard build log and how keyboards work: https://linustechtips.com/topic/1328547-mini_cardboard-a-4-keyboard-build-log-and-how-keyboards-work/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 3 minutes ago, minibois said: PCIEx1_2? It should be connected to M2A or M2B. It won't work on M2B though, so you need to have it connected to M2A. He's talking the m.2 port above PCIeX1_2 12 minutes ago, Youngsinarta said: I put in a m.2 (Mx500 500gb) as my primary boot drive was running out of space and i wanted to migrate it, it is connected to pciex1_2 and will not show up on the bios or windows (I do eventually want to migrate my ssd onto the m.2) I had updated my bios to the latest version to which ive read can cause some issues, though i'm not sure. Thank you. The M.2 port that's above PCIeX1_2 is NVMe only. You have to put the MX500 on the upper m.2 slot as that is both NVMe/SATA, if this is the right motherboard MAIN PC: CPU: Intel® Core™ i9-9900K Processor Motherboard: Gigabyte Z390 Aorus Pro Wifi CPU Cooler: Scythe Fuma 2 GPU: EVGA RTX 3080 FTW3 Ultra RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15 Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home Headphones: Philips SHP9500s Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV) SECONDARY PC: CPU: Intel® Core™ i3-9100F Processor Motherboard: ASRock Z390 Phantom Gaming 4-CB CPU Cooler: Arctic Alpine 12 CO GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16 Case: CyberpowerPC Onyxia PSU: ATNG ATA-B 800w 80 Plus Bronze Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM OS: Windows 10 Home Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 11 minutes ago, MrBrightSyde said: He's talking the m.2 port above PCIeX1_2 The M.2 port that's above PCIeX1_2 is NVMe only. You have to put the MX500 on the upper m.2 slot as that is both NVMe/SATA, if this is the right motherboard The top m.2 slot shares 'resources' with the pair of S-ATA slots up in the top right of your image, notably the first one. If that's populated, you can't use that S-ATA slot, @Youngsinarta. BTW - both m.2's are NVMe. I frequently edit any posts you may quote; please check for anything I 'may' have added. Did you test boot it, before you built in into the case? WHY NOT...?! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 4 minutes ago, Eighjan said: BTW - both m.2's are NVMe. And only the top m.2 connector is SATA M.2 compatible, which was my point. He's using the MX500, a SATA m.2 drive. @Youngsinarta You also need to change which SATA port your SSD is using. MAIN PC: CPU: Intel® Core™ i9-9900K Processor Motherboard: Gigabyte Z390 Aorus Pro Wifi CPU Cooler: Scythe Fuma 2 GPU: EVGA RTX 3080 FTW3 Ultra RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15 Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home Headphones: Philips SHP9500s Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV) SECONDARY PC: CPU: Intel® Core™ i3-9100F Processor Motherboard: ASRock Z390 Phantom Gaming 4-CB CPU Cooler: Arctic Alpine 12 CO GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16 Case: CyberpowerPC Onyxia PSU: ATNG ATA-B 800w 80 Plus Bronze Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM OS: Windows 10 Home Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 3 minutes ago, MrBrightSyde said: And only the top m.2 connector is SATA M.2 compatible, which was my point. He's using the MX500, a SATA m.2 drive. Ahh... I frequently edit any posts you may quote; please check for anything I 'may' have added. Did you test boot it, before you built in into the case? WHY NOT...?! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 Author 1 hour ago, Eighjan said: n/m EDIT: Have you got any of the S-ATA ports populated? If so, which ones? It was originally for my HDD and SSD but i put them on ASata as it isnt detected when the M.2 is connected. Originally it was on Sata 0 and 2 but now its on ASata, I will try doing what the other person has recommended and put the M.2 on the top slot and then change the SSD and the HDD back to sata so it doesnt share bandwith Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 Author 1 hour ago, MrBrightSyde said: He's talking the m.2 port above PCIeX1_2 The M.2 port that's above PCIeX1_2 is NVMe only. You have to put the MX500 on the upper m.2 slot as that is both NVMe/SATA, if this is the right motherboard Oh right I see, the problem is basically that the actual M.2 drive isnt long enough for it to go on the type 22110 ( as in i cant really screw it down) , and that my graphics card basically blocks it out of view anyways. I figured it may be the case but i dont want the actual drive itself to be hanging out at the 30 degree incline, unless its safe to do so and that there isnt any risk Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 1 hour ago, Youngsinarta said: Oh right I see, the problem is basically that the actual M.2 drive isnt long enough for it to go on the type 22110 ( as in i cant really screw it down) , and that my graphics card basically blocks it out of view anyways. I figured it may be the case but i dont want the actual drive itself to be hanging out at the 30 degree incline, unless its safe to do so and that there isnt any risk This will make the top m.2 heatsink useless but you can take the heatsink off, see that there are other holes to mount a standoff, unscrew and move the standoff to the one labelled 80 and you are able to screw in Type 2280 M.2 drives. Edit: Picture for clarity MAIN PC: CPU: Intel® Core™ i9-9900K Processor Motherboard: Gigabyte Z390 Aorus Pro Wifi CPU Cooler: Scythe Fuma 2 GPU: EVGA RTX 3080 FTW3 Ultra RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15 Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home Headphones: Philips SHP9500s Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV) SECONDARY PC: CPU: Intel® Core™ i3-9100F Processor Motherboard: ASRock Z390 Phantom Gaming 4-CB CPU Cooler: Arctic Alpine 12 CO GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16 Case: CyberpowerPC Onyxia PSU: ATNG ATA-B 800w 80 Plus Bronze Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM OS: Windows 10 Home Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 1 hour ago, Youngsinarta said: It was originally for my HDD and SSD but i put them on ASata as it isnt detected when the M.2 is connected. Originally it was on Sata 0 and 2 but now its on ASata, I will try doing what the other person has recommended and put the M.2 on the top slot and then change the SSD and the HDD back to sata so it doesnt share bandwith The top m.2 slot and the first A S-ATA port use the same resources & can't be used at the same time. The bottom m.2 slot is for NVMe drives ONLY - yours is S-ATA m.2. I frequently edit any posts you may quote; please check for anything I 'may' have added. Did you test boot it, before you built in into the case? WHY NOT...?! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 8, 2020 1 hour ago, Youngsinarta said: Oh right I see, the problem is basically that the actual M.2 drive isnt long enough for it to go on the type 22110 ( as in i cant really screw it down) , and that my graphics card basically blocks it out of view anyways. I figured it may be the case but i dont want the actual drive itself to be hanging out at the 30 degree incline, unless its safe to do so and that there isnt any risk The m.2 heatsink will hold the drive down... see page 18 in the manual for the procedure. I frequently edit any posts you may quote; please check for anything I 'may' have added. Did you test boot it, before you built in into the case? WHY NOT...?! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
