Will RGB ever die out like camo motherboards?
Guest
Will epileptic people ever roam in PC stores without fear?
1 minute ago, Turkiye1923 said:
No don't think so RGB doesn't disapear soon
Thinking about the long game here.
bir de donanımhaberde olmayan türk görmek de güzel
Honestly I'd buy the shit out of a camo motherboard.
I liked the camo or other silly boards over RGB
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
Still sure?
Atleast you can shut the RGB off. Camo,etc. are there forever
your pick it was only a few
RGB is quite customizable, and you can also turn it off as others've said
1 minute ago, Grumpy Old Man said:
Will blind people ever can enjoy RGB-lighting ???
Idk, Is your refrigerator running?
RGB is mostly an option, much like people who put lights all over their cars. It's usually completely pointless to do unless you're using the desktop in some kind of show-room environment, or are DJ'ing something and need light synchronization. At home, there's nearly no practical reason and the PC as mood lighting is no better than LED color-changing bulbs. Yes it looks cool for some situations, but mostly you're just burning energy to light up a space you're not looking at most of the time.
My previous desktop chassis came with fixed RGB lights in the front facing fans that I eventually replaced with better non-LED PWM fans, and as a result less light pollution and noise in the room it was used in.
My main problem is high end/performance parts almost always having RGB. At least in cars you have a choice.
You can usually just turn it off in software. But the extra cost of the LED's aren't refunded in doing so.
14 hours ago, Berkomeister said:
Still sure?
Yup. Even better if they made it in UCP but alas, they do not. I remember some brand, don't remember who exactly, had white/gray/black camo pattern printed right on the board itself. Looked pretty good honestly. I understand it looks tacky as hell but I liked it.
I can see what you mean but only in white/gray boards. Actually now I think of it the brown camo would be a good match with noctua fans
Doubt it though if you have an issue turn it off. I have all mine set to one colour and my keyboard to all white
Dirty Windows Peasants :P ?
Does this interfere with the RGBible ?
Hi
hi
what? epileptic people?
rgb makes the pc faster
camo makes you invisible when browsing the web and it makes the PC more stable
that are facts
Quote
Scientifically proven
Edited by Drama Lama
Hi
hi
NO
Of course not. Honestly I think you should be banned for even thinking that
Either @piratemonkey or quote me when responding to me. I won't see otherwise
Put a reaction on my post if I helped
My privacy guide | Why my name is piratemonkey PSU Tier List Motherboard VRM Tier List
What I say is from experience and the internet, and may not be 100% correct
And your Duty to take that Option whenever possible
Hi
hi
