ryzen 3700x temperature spike due to small heatsink?
thirdparty
image.png.da73d4fa01ea854e4204ce338f4906a7.pngIs this normal for 3700x idle (tried max out the cpu fans, temperature is lower but the spiking is still there)? temperature is much lower when gaming somehow (50-60 max). Or is that anything wrong with the motherboard sensor? Hope someone with similar issue/ observation can guide me through this. Thanks.
System specs:
3700x
arctic freezer 34 duo
B450m mortar max
Define mini C with 4 fans
  • CPU
    Ryzen 7 3700x
  • Motherboard
    MSI B450M Mortar Max
  • RAM
    Klevv Bolt X 3600mhz CL18 overclocked to 3600mhz CL18 @ 1.35V. (latency 67 ns)
  • GPU
    Gigabyte Windforce GTX 1080
  • Case
    Fractal Design Define Mini C Windowed
  • Storage
    1TB HDD from Toshiba, 250 gb Samsung 850 evo, 2TB Western Digital SN750
  • PSU
    Superflower Eco Silver 600W
  • Display(s)
    Dell U2417H
  • Cooling
    Arctic freezer 34 esports duo, Arctic P12
it is normal
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
Its normal for ryzen .. Have 3 3300 and 5 3600  its same even with overkill liquid cooling ..
I know one way to "fix" it .. OC :P
3 3300 is on 4.4ghz  and 5 3600 on 4.2ghz.. No spikes
