Sound Card for headphones
Kasenumi
Hello guys
Would Asus Xonar AE sound card do any difference with my Beyerdynamic DT990 600 ohm, Liquid Spark AMP and Geshelli Labs ENOG2 Pro DAC?
My friend who is good with hardware keeps telling me it would be an upgrade comparing to integrated MOBO soundcard of AB350 Gaming 3 MOBO?
Case: Fractal Design Torrent;
GPU: MSI GeForce RTX 2080 GAMING X TRIO 8GB;
RAM: G.Skill Flare X, DDR4, 16 GB,3200MHz, CL14;
CPU: AMD Ryzen 7 2700X,
CPU Cooler: Noctua NH D15;
MOBO: Gigabyte GA-AB350-GAMING 3;
PSU: be quiet! 700W PURE POWER 11CM 80+Gold;
SSD 1: SanDisk Extreme PRO 500GB PCIe x4 NVMe;
SSD 2: PLEXTOR PX-1TM9PeY 1TB SSD
53 minutes ago, Kasenumi said:
Hello guys
A sound card is basically an internal DAC chip, you already have a DAC so there's no reason for you to buy another one.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
I might sound stupid but I feel like I am a beginning audiophile with lots of questions, if I am wrong in my thoughts I will express - please correct me.
The sound source is MOBO. AMP powers and processes digital sound coming from MOBO and improves it resulting in better quality sound that we hear in headphones. DAC clears "dirty" sound and noise. Good quality RCA cables help DAC and AMP to reduce the noise so the sound coming from headphones is "as clean as possible".
Wouldn't the better quality source of sound, which is a PCi E sound card make overall sound better and more pleasing?.
The digital signal coming out of your PC is an exact version of the audio being produced on your PC. The motherboard DAC and AMP are what can degrade this signal by converting it (poorly) into analogue. You already have a Geshelli from what I understand that is used as a DAC, you cannot use multiple DACS. All a DAC does is turn digital audio into an analogue signal. I go through this in detail in the interface section of the guide in my signature, take a look at that if you're not quite following.
@rice guru
I use an old sound card SB0880 and it blows my onboard audio out of this galaxy.
