260 watt power supply.
9 minutes ago, Spotty said:5.08V and 5.08Vsb???
"Hey boss, we can't quite get the voltage regulation tight on the 5V. It's a little high. Do you want us to make some design changes?"
"No. I've got a better idea..."
They intentionally configure the voltage a bit higher, to account for losses due to using thinner wires on the power supply.
It's not a problem, the atx standard says acceptable voltage is 5v +/-5%, so anything between 4.75v and 5.25v will be acceptable without any issues by all components in your computer.
To the original poster, the power supply can provide up to 216 watts on 12v, which is the voltage used by the more power hungry components like processor and video card.
Besides these two, fans consume around 1-2 watts each, mechanical drives consume around 5 watts each from 12v. SSD drives typically consume only 5v
So currently your computer consumes about this much
i5-2400 - maybe 50w average, let's say reserve 65w
motherboard - maybe 5-10w on 12v, the rest on 3.3v and 5v to power chipset, audio chip, network card
8gb ram - probably powered from 5v of your power supply, but less than 5w either way.
gtx 1050 2gb - under 75w, probably are 60 watts
500 gb drive - 5w on 12
ssd - 2-4 watts from 5v, nothing from 12v
another drive - another 5w
let's add 5 watts for cpu fan and some case fan
So you're looking at 65w cpu + 10w mb + 75w gpu + 10w hdd + 5w (fans) = 165 watts on 12v .... you have 216w on 12v , so there's still around 50 watts you can use.
If you remove the video card, without video card your system will consume around 100 watts, so you're left with up to 116w ... but you should not go over 100 watts, leave some room ...
So you have some choices at less than 100w or near 100w
GTX 1660 Super = 8W/110W
GTX 1650 = 8W/80W
GTX 1650 Super = 8W/95W
GTX1050Ti = 6W/75W
GTX1050 = 6W/75W
