I have all of my parts in... now it’s on to wiring which I have little to no knowledge about. I try reading the manuals but I’m still dumbfounded. Any help or info I’d appreciate it.
PC Specs
asus Rog Strix z390-e
Corsair H115i RGB Pro
Corsair Hxi 750 PSU
https://linustechtips.com/topic/1206834-building-my-first-pc/
PC Specs
Corsair Hxi 750 PSU
What wires is it that you're wondering about?
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697700
You come to the right place.  This is a forum for a YouTube channel that builds computers.  I would start by watching those.
https://www.youtube.com/user/LinusTechTips
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697702
PC Specs
Corsair Hxi 750 PSU
Watch a video from Linus Tech Tips
Hi
hi
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697712
... Lad where's your CPU, GPU, RAM, and Storage?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697720
Didn’t list them I use M.2 storage CPU and RAM is already installed I’m just stuck on wires. GPU I don’t have yet but that goes in last anyway and i9 has integrated graphics so it’s fine while I save up for it
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697788
6 minutes ago, youngboy said:
You are missing a lot of parts. Here is a list of the parts you need. You have 4 of then:
CPU
Motherboard
Case
RAM
Storage
Graphics Card
Power Supply
CPU Cooler
Case Fans
You have a motherboard, CPU cooler, and Power Supply.
To know how to assemble them, watch this video:
I didn’t list the ones that don’t require wiring. I have them all but GPU.
Asus Rog Strix
Intel i9
corsair h115i rgb pro
corsair dominator platinum
Samsung 970 evo plus
cooler master Masterbox k500
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13697797
1 hour ago, youngboy said:
Great then. Watch that video to know how to assemble your PC. I suggest you watch about 3 videos before you assemble your PC. Here are the 3 videos you should watch to know how to assemble your PC:
I’ve been watching the videos but I’m brain dead when it comes to wiring and hooking things up. I’m literally lost I only have a couple fans plugged in and the CPU and Motherboard power pins plugged in. There are cords everywhere and I suck at this😁🤣
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13698112
I did watch them but I’m brain dead with wires and very lost still I literally need someone to sit here and tell me specifically what is what if I want to get anything done. I’ve made little to no progress within the last couple hours and what I have plugged is is a mess all of the case there’s no way of cable managing any of it.
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13698134
Just now, youngboy said:
You should have watched the videos before starting your build.
In all honesty I have watched those videos before I just used them as a refresher (which obviously didn’t work) I just don’t know what’s what and what goes where it’s confusing me with 100 wires in front of me and not knowing what goes where
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13698211
4 minutes ago, youngboy said:
Here is a tip I used on my first build. I also struggled with wiring, so here you go:
Write down the names of all the wires you need to plug in, especially for the power supply. Write down all the wires you need to plug in. And then, all the wires plug into the motherboard, know that. All the wires plug into the motherboard. So once you've written down the names of all the wires, you go to plug in and in order of you writing them down, plug them in. That's like a checklist for yourself. Make a checklist by writing down the names of all the wires. Hope that helps you
I will try this out and see what happens all I know is there is lots of cords and wires everywhere. All over my desk and hanging in the case.
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13698220
Hi, I’m going to be posting a lot of these so I can get answers quicker and I’ve been stuck for quite a while now. Unless someone have the time to help me out directly over private messages (if you do just pm please). If not that’s fine I’ll gonna post a new thread every time I go so they are seen more often.
Anyway, I’m building my first PC and I’m down to the wiring (I’m kinda mental when it comes to wires lol). My question is what does this cord plug into on the motherboard? It says RGB HUB on it but when I plug into “RGB HEADER” it doesn’t stick, it’s very loose.
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13699061
Don't do that
- Moderation team
Merged your post with your existing thread asking for help with how to build the PC. Feel free to reply to this thread and ask follow up questions on how to assemble your system.
Good luck building your PC! Take it easy and don't rush. Don't be afraid to stop and check a guide or the instructions/manual if you get stuck.
https://linustechtips.com/topic/1206834-building-my-first-pc/#findComment-13699073
