2.1 Speaker Set - I need help, Guys!
I just looked around for a tiny bit and here's what I found: http://www.amazon.com/Klipsch-ProMedia-Certified-Computer-Speaker/dp/B000062VUO (same one except not in the U.S. http://www.amazon.co.uk/Klipsch-Pro-Media-Certified-Speakers/dp/B009L1NY0M/ref=sr_1_fkmr0_1?ie=UTF8&qid=1393255950&sr=8-1-fkmr0&keywords=Klipsch+ProMedia+2.1+THX+Certified+Computer+Speaker+System+%28Black%29 )
According to the many reviews they have, the speakers are good for all ranges and they're really good for the price. I only regret that I can't give you a first-hand experience. Take this with a grain of salt because of the lack of handling them myself. I'm not sure if they're the best, but I can guarantee you that they won't work with your PS3 natively. You'll need an adapter for that;
You'll need the RCA output for the PS3 and route it through there. Just connect the adapter and plug it in. I do the same with my PS3.
I hope I was helpful in any way.
