So today I bought a fan splitter for my 3 pin fans. Splitter has 4 pin connector which connects to motherboard, other two are for fans and they are 4 pin and 3 pin.
That 3 pin connector is very weird because it isn't a tipical 3 pin fan header. It has 2 pins , then empty space and then the last pin.
Can I connect 3 pin fan to 2 pins?
https://linustechtips.com/topic/1201179-question-about-fan-splitter/
yes you can use 3 pin fans on a 4 pin header. the point of missing the pin if I'm not mistaken is to only report back 1 RPM
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
The first 2 pins are power connectors, the 3rd pin (missing one) is the rpm sensor and the 4th one is the pwm connector.
You can use the splitter to split to two fans but you will of course only get the rpm readout from one fan.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
I know that I can use 3 pin fans on a 4 pin header, but can I use 3 pin fans on a 2 pin header?
I was worried that I got broken pin header. Thank you!
Yup, pin 3 is 'sense', to see how fast a fan is moving. The motherboard expects to get speed back from one fan, which is why it's only on one of the male ends.
Yes.
Pin 2 is used for speed control (be sure to set your motherboard to DC control on that header). Pin 3 is to ask one fan how fast it is moving.
Keep in mind with a splitter, all connected fans to that splitter will move at the same speed.
Yes.
So, if I have two 3 pin fans, one can spin max at 1500 rpm and the other one at 1000 rpm, both are going to spin at 1000 rpm?
Just now, SleepingGiant20 said:
So, if I have two 3 pin fans, one can spin max to 1500 rpm and the other on at 1000 rpm, both are going to spin at 1000 rpm?
No both would spin their max
But you said "at the same speed". 1000 RPM fan cant go to 1500 RPM.
That was assuming identical fans. If you only using 3 pin you’ve got voltage controlled speed so they never will be at the same speed.
Your motherboard doesn't work with RPM, it works with %:
(This is just an illustrative example)
So if you set it up so they both run at 100%, they will run at 1500 and 1000RPM respectively. If you set them up at 50%, they will run at 750RPM and 500RPM.. etc.
It's just that they're both at the same %.
