How to turn volume lower than 1 ios
The Torrent
My ears r bleeding now I use an inline DAC it’s too loud!!
is it possible? Can I use some haxx?
I haven't been on iOS is quite a while, but I remember there used to be a way to use the volume slider in the menu with a bunch of different buttons that I forget the name of, I think you access it by swiping down on the battery life icon. The slider gives you access to many more steps than the side button does, although I don't know that it will get quiet enough for your needs. Its also quite finicky to do it that way
What version of iOS? If it's one of the newer ones, you can swipe down diagonally from the Battery Icon.
As said, the Control Center allows you to get more fine tune controls
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
no it doesnt give me more fine controls even if i move it a pixel up its equal to 1 step.
I apologise for commenting this but in the same way I'm obligated to say "this is why I don't ever recommend USB microphones" every time someone has an issue with one,
This is why I'll never recommend Apple devices, user friendly? maybe but an absolute pain in the ass whenever you want a feature that's been around on Android for generations? Absolutely.
Also, maybe this really old post will be useful.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
Sloth
The solutions don’t apply for me as this isn’t an iPod and I’m not using the music app.
im wondering if anyone knows of any other updated ways available now.
The only thing I can think of is to get an in-line volume control - similar to this:
https://www.amazon.ca/Stellar-Labs-1013015470-Control-Headphones/dp/B008DJTB32
You could try to jailbreak your iOS device, but even that won't necessarily guarantee you doing what you want. That simple adapter should do exactly what you need.
Inline volume controls are something most people actively avoid when buying headphones as they introduce a massive point of failure and have a tendency to break in weird and wonderful ways that result in volume differences between the left and right sides. I definitely wouldn't suggest purchasing one.
Sloth
@rice guru
Sloth
Do you suggest an alternative solution? Because I see no other option.
Yes, don't use the inline amplifier.....
@rice guru
So, no. You don’t have any other suggestions for a solution.
Occam's Razor, the simplest solution is almost always the best.
@rice guru
OP shouldn't even need a DAC or amplifier for something like an iPad, iPhone or iPod. If OP has an iPhone 6s+ or older or an iPad Air 2 or older or iPad Pro (first gen I think he can just plug his headphone into the headphone jack. If he has a newer Apple device use the dongle
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
I don’t disagree. I’ve had various iPhones and they all sound great with my HD 6xx and HD 598’s. But if the OP is adamant, at least I’ve given him an option.
How is he using a DAC with it? Can the charging port accept usb devices? Never used the charging port on my iPad or iPhone for anything other than charging.
  • My system specs
  • ROG PG279Q
  • ROG Sica
There are dongles for that.
He does not need it, but it improves sound quality quite a lot.
I thought so too, then I tried a dac and the quality difference was very noticeable, no matter how cheap or high end headphones or dac combos I used the difference was noticeable, mileage may vary though.
Just curious, what dac and headphones are you using?I tried quite a few dac's and headphones with ipad/iphone and never did my ears bled when the volume was set on 1.
Yes, definitely, earsplitting volume is always better quality audio than reasonable volume decent headphones......
@rice guru
Sarcasm is a cool thing. So if he uses a dac it only means that it's just makes it louder and does not improve quality?Or what do you mean?You are the pro here, please educate me.
I use this https://www.amazon.com/AudioQuest-DragonFly-Red-Headphone-Amplifier/dp/B01DFMV4NQ  with ipad, when volume is on 1 my ears are far from bleeding.
Edited by nox_
no i use an inline dac and amp. amps can also improve sound quality.
im figuring theres no way then? the dongles mentioned wont work as previously mentioned it is a inline dac.
im using audeze el-8 Titaniums with the cipher dac. a lot of the time its ok but at night my ears are like super sensitive and the first volume is just tooo loud.
12 minutes ago, The Torrent said:
with the cipher dac
You use 5 k dac and 800 usd heaphones with an iphone? :D Odd choice if you ask me, but that's me.
I think there isn't.
The Audeze Cipher DAC is under 130USD.....
And the EL8 Titaniums are about 250 used or a $500 street price IIRC...
Really not sure where you get your prices from.
@rice guru
5k dac? no cipher cable is an inline dac that comes with the headphones.
i didnt buy them 'street price' tho lol and they are more expensive in the uk. i bought them maybe 2 years ago i did pay around 800ish
Couldn't find the Cipher Dac anywhere for sale, only found Cipher DAC from other manufacturer and that costs 5k, now I found the right one :D Titaniums in my country go for around 700 euros which is around 760 usd.
@The Flying Sloth
Oh, sorry about that, the name confused me. Found it now.
