RTX 2080 Super power bottleneck?
riyuuu
Hi, I wanted to know if it was possible that my card was running at such low gpu usage that it might be my OCZ 600 W bottlenecking it.
I used to have a 1080ti that was running better fps and was using the same PSU and evertything else.
Thank you.
Usually related to power it either works or doesn't... then again I cannot think of any OCZ 600W PSU you should be pairing with a 2080 Super.
Your fps could be broken due to drivers likely, DDU in safe mode and reinstall drivers fresh new.
Personal Desktop":
Luna, the temporary Desktop:
Ok, I think I'll just give up on this card, it ain't normal that I pay for maximum FPS running everything on low @ CSGO and get lower FPS than my monitor RR. I posted a video on YT so you can experience the insult that my GPU is...
https://youtu.be/zEvV5RA1r-g
Honestly, I'm not sure you're blaming the correct part in here. The GPU is likely fine.
Did you bother reinstalling the drivers like mentioned? Use a non garbage PSU?
What is your entire system? Csgo is a terrible game to check if performance is right due to how outdated it is, it runs worse on the latest hardware.
Personal Desktop":
OCZ is not garbage, but it is from 2011, I'm confident that some people out there are running there 2080 Super perfectly fine but yeah when I upgraded my RTX 2080 Super I did reinstall all the drivers so I'm already using the latest available driver.
I already made the decision of buying a 1000+W psu for the future.
I appreciate you trying tho, I'm probably just bad with computers...
Thanks bro
Thanks bro
Well capacitors and rails and vrms age overtime so it could be bad power delivery
Phone: Pixel 3a (Purple-ish).
Build Log:
