difference between dual channel and quad channel memory
3 minutes ago, mariushm said:Socket AM4 is only dual channel. You have 2 channels, each with up to 2 sticks of memory, depending on memory layout. It's not quad channel, quad channel is Threadripper.
Just saying because I think you're confused and think that having 4 memory slots on motherboard means quad channel, which is not the case.
There will be no performance increase or very minimal increase from using 4 memory sticks instead of two, if the total capacity is the same.
Depending on how the memory sticks have the chips arranged on them (single rank, dual rank etc) in SOME applications that read and write small data very much in ram, there may be a small performance increase using 4 sticks. But it's so little and in so few applications that it's not worth stressing about it.
Some motherboards have a harder time powering 4 memory sticks and handling signals from 4 memory sticks at the same time at very high speeds, so in some cases you would see 2 sticks working at 3600 Mhz but with 4 sticks you may only be able to configure 3200 Mhz or even 3000 Mhz.
oh did not know that thanks
