2666mhz DDR4 vs 2667mhz?
Solved by WereCatf,
9 minutes ago, fastfishy2 said:Motherboard I'm looking at (Gigabyte B450M S2H) quotes memory compatibility with DDR4-2667 however the only RAM available locally is 2666mhz. Is this going to cause any issues or is it just a difference in terminology and the 1mhz difference won't do anything?
The 1MHz-difference is a rounding-error, you should just ignore it.
Featured Topics
Beeswitt ·
Posted in Troubleshooting1 -
3
CrowTheRobot ·
Posted in Windows1
