Thermaltake v200
Solved by Eschew,
Hey there. I took a look at the Thermaltake V200, here's what I thought about it:
- Airflow intake seems to be limited to a small gap under and to the side of the front panel, and to the tiny gaps around the tempered glass panels. Things inside'll get pretty toasty.
- The PCIe brackets are those non-reusable types. Might want to keep this in mind if you plan on upgrading your rig down the road (Wi-Fi cards, sound cards, etc.).
- For €55, I'd say it's an okay choice. You get all the bare necessities, basic front I/O ports, and plenty of room that'll accommodate pretty much any standard PC build.
Personal Opinion: If it were my money to spend, I'd save up and invest it in a more long-term solution like the Fractal Design Meshify C or Cooler Master MasterCase H500. But, hey, it's €55.
