Hello, i'm planning a custom loop and i was wondering what fluid color you guys think would look good in this build. the loop is going to consist of a 480mn the front, 480mn the side and a 360mn top with a cpu monoblock and the graphic cards will be liquid cooled as well. I was thinking clear but what are you guys opinion?
https://linustechtips.com/topic/1166932-what-fluid-color/
i think you should turn your PSU around because like this it will, even with dust filters, suck in your entire carpet over time.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13390544
My psu is side mounted in the back of the case. those on the bottom are my hard drives
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13390654
1 hour ago, NZgamer said:
I think green would be a good loop colour, but you don't seem to have a set colour theme here so I guess you could go with anything, unless you wanted to start a theme by changing the RGB colours to match the loop?
What theme would you suggest trying? right now my theme is rainbow light show and i mean i do like the shifting colors
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13390655
dont use colored fluid at all for watercooling if its a daily driver.
think about painted tubes instead, like i did ;)
  • CPU
    Intel i7-8700k
  • Motherboard
    ASUS ROG Maximus X Code
  • RAM
    32GB Corsair Vengeance LPX DDR4 3000MHz
  • GPU
    2x ASUS Strix 1080Ti OC
  • Case
    Fractal Design Define R6 Gunmetal TG
  • Storage
    250GB Samsung 960 EVO
    2x 500GB Samsung 850 EVO
    1TB Samsung 860 EVO
    2x 256 GB Samsung NVME SSD
  • PSU
    Corsair HX1000i
  • Display(s)
    Alienware AW3418DW 34" 21:9 1440p
  • Cooling
    Custom watercooling loop with 2x 360 Rad + 1x 560 Rad
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13391528
Great case choice!
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13402692
Clear and use rgb. But I swapped to matte black hoses for my builds. So back to distilled water for me.
https://linustechtips.com/topic/1166932-what-fluid-color/#findComment-13404118
