3 minutes ago, MrChris said:
problem with sending my finished Folding project. its project 11758. it has faild 8 times now. what should i do?
im new to this so dont really know what im doing :P
Wait, it seems the Folding servers are somewhat overcrowded.
Most liekly it will get trough once it can.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13374194
agreed, stuck downloads has been an issue for me
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13374210
The F@H servers are under heavy load due to events ramping up to fight Covid-19 by the LTT community, PCMR on reddit and others. Just be patient, it will upload eventually.
ESL Profile: https://play.eslgaming.com/player/2432327/
F@H Profile: https://folding.extremeoverclocking.com/user_summary.php?s=&u=847206
Old System:        Current System :
i7-3770k + Cooler Master Hyper 212                           i9 9900k + Noctua NH-D15
Gigabyte Z77M-D3H                                                    Gigabyte Aorus Z390 Master
Evga Geforce GTX 970 SC                                          GIGABYTE GeForce RTX 2070 SUPER GAMING OC (F@H OC +70core/+580 mem)
HyperX FURY Red 16GB  DDR3 1600                        Corsair Vengeance  LPX 2x16GB DDR4 3200
bequiet PURE POWER 600W 80+ bronze                  Corsair RM 650x 80+ gold
Samsung 850 Evo 120 GB + 1TB HDD                       Samsung 970 Evo Plus 500GB
        Thermaltake Level 20 MT ARGB
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13374236
I notice 11758 isn't even showing as a known project in their database.  I assume this is just an oversight due to the priority being on getting more work units out there?
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13376031
Indeed, also their servers are getting slammed I'm sure.
It's also shown in the project list https://apps.foldingathome.org/psummary
Most/All projects with 117xxx is CV related, i might be wrong as I'm trying to use the same server you are to figure it out, but everything that works that surrounds 11758 is the same disease
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13384811
Please fix your link, it points to some weird site. (copy the adres into the URL part.)
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13386542
Read the sticky at top here: LTT Folding Team's Emergency Response to Covid-19
Quote
[NEW!] Possible failure to upload completed WUs 11753 & 11758 to work servers 155.247.164.213 & 155.247.164.214. F@H are aware and are investigating the issue. Read More...
Seems like there's a bug on F@H's side
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13386612
My client is spending more time inactive (nothing being downloaded or worked on) than it is doing anything else, I assume it is because of the same thing, the servers are all overloaded?
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/1165043-fh-need-help/#findComment-13387627
