So I can seem to find information on why capping your battery charge to 80% is good in the long run but cant seem to find any info on an approximation of how much longer it should extend the life. Basically I'm trying to decide if its worth it to lose the 20% capacity day to day.
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
It protects the battery life by keeping the battery healthy.
i'm no battery expert, but i have heard that it is good for a battery to run it down all the way and charge it up all the way regularly.
My build
Ryzen 5 2600 @3.95ghz
Cryorig M9a
Gigabyte x470 Ultra Gaming
Gigabyte RX 590 @1720mhz
2x8 Corsair LPX Vengeance 2933
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
WD Blue SATA SSD 500GB
I do know that and I've seen that video too but I just didnt know if it extends the lifespan of the battery a significant amount in the long run
Rainbow Barf
I personally have not seen or found a study that does a long term review like that, but I've admittedly also never looked for one.
I CAN tell you from my experience with Hobby Racing RC cars that batteries do like to be used through most of their % power which makes them last longer (as opposed to recharging at 50%), and usually they're stored with 30% of their power when not in use. NiCAD batteries especially, but it's still a good practice with niMH and LIPO/Li-Ion (batteries found in our smart phones)
That's actually the exact opposite of what's good for it.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
not often, but you should run it down, and back up every now and then.
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
This actually has the opposite effect and is worse.
The larger a battery is the faster it degrades. I won't pretend to know the physics or chemistry behind it . Laptop batteries will lose capacity faster than phone batteries if you treat both the same.
The ideal way to treat a battery is to charge it to 80% and make sure it doesn't go below 30%. The ideal charge level to keep your phone at is roughly 50%.
Charging your phone from 80% to 100% is just as damaging as charging it from 0% to 80%.
Also the temperature of the battery will affect it's lifespan, if the battery is too hot or too cold it'll get worn down faster.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
As I understand it -- a popular theory is that since a lithium ion battery has, more or less, a finite number of full capacity charges it is rated for/can sustain you want to avoid using up those charge cycles.  A way to do that is to never consume a full charge cycle (0% - 100%).  So if you're only ever using a fraction of a charge cycle then you're rationing out how quickly you will consume the entirety of the healthy life of the battery.
Another theory (perhaps not so different from the first) is that the extra electrical/chemical? effort it takes to fill a battery from 80% to 100% puts avoidable stress on the battery.  Think of blowing up a balloon with air.  Filling it most of the way is easier than the last bit of effort it takes to make it completely full.  Now that isn't a perfect analogy in that it points to the stress of the charger than the battery so assume there also exists stress on the vessel as it is being filled.
No.  You'd only want to do this in the event the calibration was off.  For the life of the battery that should be avoided.  As goes the theory.
See I've heard the opposite for NiCAD, niMH versus Li-Ion.  Things like battery training are a benefit to NiCAD, etc but not to Li-Ion.
If you want some anecdotal evidence then I can tell you that a couple phones ago I always put the phone on the charger for the duration of the night and that battery went to shit.  So the phone after I almost never left it to charge overnight (maybe 5 times accidentally) and only charged as needed (sometimes to 80% and sometimes to 100%).  The major difference between the charging habits being the overnight sitting on the charger.  The latter had a rock solid battery when I was done with the phone so as such I passed it on to someone else.
That was true in 2005-ish. Li-Ion and LiPo batteries don't need to be heavily drained then full charged because there's no "memory" to retain, as in NiCad. Modern batteries last longest when drained to about 30% and charged to about 70%, and deep draining them actually causes more harm than good because of the amount of heat generated when a battery is left charging for that long. Wireless charging is also bad, and for the same reason. Lots of heat, and heat is the silent enemy that will eventually kill 100% of electronics.
Some phone manufacturers are putting in an intelligent charging option now that learns when you charge your phone and sets it to only charge the battery to 80-90%, then sit there until bumping to 100% shortly before you usually take it off the charger. Laptop manufacturers are doing something very much the same by allowing you to set a maximum charge threshold, and even if yours doesn't, there are programs out there like BatteryBar Pro that can ding at you when the battery hits the thresholds you want it to do so at.
NiCad's a different story, ditto NiMH, because those batteries are recharged via crystals (IIRC), and those crystals will hold less and less power over time. Recharging them from any point above 0% would "reset their memory" and make them consider that the zero point. I don't remember the exact chemistry of it or exactly how it worked, but that was the general idea. Some form of memory in the battery would shift the zero power point.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
I wouldn't worry about it. It's mostly useful if you have a laptop that rarely sees usage outside of being plugged into the wall. Chances are by the time you notice the difference it'll be time to get a new device, or if you keep your devices for a long time, just get a new battery.
Cycles aren't from 0 - 100 only. You don't dodge that bullet if you never let it drop. A charge cycle counts as any time the battery's capacity is consumed. So charging it 20% 5 times would be one charge cycle. The last bit has to do with heat.
Charging circuits are smart enough to cut off the charge when the battery is full. Highly doubt leaving them plugged in like that caused that much of a battery issue, it was likely the logic the phone used, or a higher quality battery to begin with.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yeah, I could have worded it better.
And I should have clarified that I didn't think the phone was constantly charging, but the fact I was always charging it to 100% every night.
