i was thinking about this
most my friends do this at home
some people say its messy and unsanitary
it does get a bit hot here so i was like "i dont care"
so what do you think guys
Side panel off or on ?
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/115585-going-nude/
Uhh. That took an unexpected turn.
On if you case has good airflow. I kept the side panel on my old case off since there were no case fans in it. (All the bearings went bad and they got really loud so I ripped them out.)
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
https://linustechtips.com/topic/115585-going-nude/#findComment-1545390
On, you need 'dat pressure!
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/115585-going-nude/#findComment-1545396
Vengeance has been running around naked for a few months now, and boy does he love it! People look at him weird, but he doesn't care.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/115585-going-nude/#findComment-1545409
If you need to take a side panel off, then you should look into why its so hot. Maybe add a fan so you don't have to. If there isn't holes to mount, then you can mod something.
Or just leave the side off. Its your decision.
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/115585-going-nude/#findComment-1545416
Abort the fap!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/115585-going-nude/#findComment-1545421
Either full clothed (side on) or stark naked (on the motherboard box). There's no point in going in between.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/115585-going-nude/#findComment-1545440
With a name like that, I'm calling child support on your ass.
You mean Tech Support?
| CPU: AMD A8 | MOBO: MSI 7778 | GPU: Asus GTX 650Ti | Case: Corsair 200r |
| SSD: PNY 120gb | HHD: WD Blue 1tb | PSU: Cooler Master 750W |
| peripherals: Corsair Vengeance M65 & Razer Black Widow Ultimate |
https://linustechtips.com/topic/115585-going-nude/#findComment-1546421
always on, i need that 200mm fan :P
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
https://linustechtips.com/topic/115585-going-nude/#findComment-1546436
