Help! Looking to upgrade my RX580
EvanM
Hello all. I'm looking to upgrade my Radeon rx580 but do not really know what would be an upgrade as I am extremely new to the PC scene. I am a Call of Duty player and am a little sad i am only getting around 75-99 fps on average with medium/low settings. I have a 1080p 144hz monitor and feel as though the 580 isn't cutting it for me. I was thinking of a 2060 super but I'm really not sure. My price point is $300-$400.
Specs
CPU: Ryzen 7 3700x
Motherboard: Asrock B450M Gaming
RAM: 16gig DDR4 300mhz
PSU: 650w Gold
But im also not planning on using ray tracing so maybe a 5700xt?
For $300 I'd nab a 2060 KO, for the $400 range aim for a 2060s or even the occasional cheaper 2070/used 1080 ti
Want to custom loop?  Ask me more if you are curious
Do you think the performance of a 2060s would be better than a 5700 or 5700xt?
A bit better than a 5700, a bit worse than an xt
Shoot for the 5700XT. It will handily outperform a 2060 and edge out a 2070 and 1080ti (in most games). You might be able to find a 1080ti used for a better price, but the 1080ti is currently as good as it will ever be. If history repeats itself the 5700XT will only get better from here with AMD's phenomenal track record of continuing to optimize cards well beyond their life cycle.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
I went from a rx580 to a rx5700 non xt at 1080p on a 144hz panel and I am very happy with my purchase. I haven't played cod on it but I doubled my framerate in my other games like siege, pub g, tarkov
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
Whats your average frames on Siege?
My current card uses one 8 pin connectors would i just use the other pcie cable for the second 8 pin? my psu is non modular
Avg I went from 107 to 175 fps
Minimum I went from 87 to 144
That's at 1080p  Ultra Preset 100% render scale
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Xbox series x
That is correct.
CPURyzen 7 5800X Cooler: Arctic Liquid Freezer II 120mm AIO with push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
MotherboardASRock X570M Pro4 GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO Case: Antec P5 PSU: Rosewill Capstone 750M
Monitor: ASUS ROG Strix XG32VC Case Fans: 2x Arctic P12 PWM Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
