Anyone with a define c that can help with measurements?
Solved by Slottr,
10 minutes ago, vong said:Perfect. So is that from the flat side of the expansion slot? Not the whole thing (like thread of thumb screws) any chance for millimeters? And or pic?
From about where the gpu slides between the case and motherboard.
Don't have mm on a tape measure, but it's about 31.5 cm to kinda meet your requirement
