I just recently upgraded my set up.  I got an i3 9100f since it is a great value and highly rated, and to match that, a Z170A Gaming pro carbon because it also has lga 1151.  I also had to upgrade ram to be ddr4 for the new motherboard so I got 8gbOLOy Dimm ddr4 3000 MHz, not brand name, but I believe it had decent reviews on amazon and I am pretty sure it is properly installed in slot 2.  Any how, the indicator light says that there is an issue reading CPU.  I zip tied my fan to it, since there are motherboard capacitors in the way of the bracket for the fan.  I am almost out of zipties so I'd prefer this be resolved without dismounting my fan, if possible.  I also upgraded my case and added a couple drives, but I doubt they are involved.  Anyhow, I boot it up and all of my rgb turns on and the fans start, so it runs, but it must be failing POST because the monitor does absolutely nothing.  I haven't cleared CMOS yet and if you think it is a very possible fix, I will do so gladly, but there is stuff in the way right now.
Also, I have a 500w PSU.
EDIT: I have decided I want to update the processor unless you can find a relatively cheap motherboard with a built in usb c slot like this one and four ddr4 slots that can at least kind of support 3000 MHz.
I live in the USA
https://linustechtips.com/topic/1152354-help-me-please/
You zip tied your cpu cooler on..?
The motherboard doesn't support that cpu.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13271732
but nope it's not compatible, you need H310, B360, B365, H370, Z370 or Z390 to run an 8th or 9th gen CPU.
8 minutes ago, milk carton said:
ddr4 3000 MHz,
only Z chipset boards can run it above 2666MHz
and with a single stick, you can only run it in single channel mode which halves the performance compared to dual channel setups (this platforms supports up to dual channel)
How low is that cooler? Probably means the Intel stock cooler is better if it's that small.
Desktop benching:
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13271741
The cooler is touching a heat sink which is touching the processor.  Got any ideas for a budget processor that fits this motherboard, or Visa versa, a good motherboard that fits this CPU?  Preferably the latter.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13271770
fan touching heatsink touching processor?
tbh the 9100F is just a 6th or 7th gen i5 built with updated manufacturing process, same quad core design and you dont even have a working iGPU, even getting an older CPU wont hurt performance, only upgrade path
any H310, B360, B365, H370, Z370 or Z390 board you can afford will do
Desktop benching:
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13271777
Your CPU is not compatible with that motherboard. These CPU's are compatible with that Z170 motherboard:
https://pcpartpicker.com/products/cpu/#f=75,73&sort=price&page=1
These motherboards are compatible with the i3-9100:
https://ca.pcpartpicker.com/products/motherboard/#c=129,136,131,130,128,135&sort=price&page=1
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13271784
That motherboard doesn't support 9th gen cpu's, you need one with a 300 series chipset, so B360 or Z390.
Also, that cooler is meant for AMD, which is why it doesn't fit. May I ask why you don't just use the stock cooler that came with the cpu?
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13272177
I spent a little bit of money on a thermaltake that said it fits most, I just need to have more RGB than my friends lol.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273208
12 hours ago, NZgamer said:
https://www.msi.com/Motherboard/Z170A-GAMING-PRO.html
6th Gen
You need a new motherboard. You should do better research next time.
Uh oh. That's a terrible idea. It needs to be mounted properly even if there are other things, it should be mounted properly using screws and not a zip tie. With your new board, ensure your cooler properly mounts to the board.
Expensive mistake.
Look, I am not the most tech savvy out there, I didnt realize that both socket and chipset matter to the motherboard and processor.  I don't plan on keeping that zipties, but I needed to install it because I actually bought that fan far before I got the motherboard and was out of money and wanted to see the cool fan glow.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273223
I'm starting to like the motherboard, which processor do you think might benchmark close to the 9100F from those?
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273230
I followed your first link and no processors were listed
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273232
4 minutes ago, NZgamer said:
Sorry but I don't recommend PC building unless you actually know what you're doing or you are being helped or guided by somebody who knows what they're doing or you're following a build guide.
Really?  Where do you think people start?  I have been building on this Dell Optiplex 980 and just haven't gotten to the motherboard or processor until now.  I don't know what I am doing with them, but by the end of this I will.  Try not to be so judgemental of me, or why did you even respond.  I'm looking for help not criticism.  Do you expect everyone who asks for help to know exactly what they are doing?  Go to a different forum, if that is the case.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273301
I looked up kaby lake, as I see this is a filter you have added.  Will Intel Core i7-8700K work for me? Will all kaby lakes?  I want to compare benchmarks and user ratings, so I keep copy and pasting everything into user-benchmark.  Is there an easier way?
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273315
1 minute ago, NZgamer said:
You start by doing research and watching videos on YouTube of other people building PCs (especially build guides) so you get familiar with it. You get to know different chipsets and processor types and other components. Then you are ready to build one. This is how I learnt to build my PC.
Look, I'm not trying to criticise you or be judgmental, all I said was that you should do better research before going out and buying all your parts.
Obviously I've done that.  I just didn't end up learning about the chipset, and now I have learned, sometimes you do it the hard way.  When I say I am not tech savvy, I am purposely humbling myself, I am saying that I am dumb compared to you and the other responders in this topic and I messed up here.  Also, I don't know how you imagine the zipties.  I have them going straight to the holes and they aren't pressing down on any components, also the fan doesnt have any extra vibration when you turn it on, it shouldn't be putting strain on anything at all.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273337
8700K is 8th generation, your mobo supports 6th gen. So that means intel processors starting with the number 6. I see you're not going for too high end, if you're only going for an i3 and single channel ram (you should definitely go for dual channel, it is much faster I think even with that i3). Can you return either the mobo/cpu? What's the GPU you're using? If you can return either one of them I would just do that and get a new cpu/mobo that fits. Though if you plan on gaming with your system for a good while (~5 years) I would get a 6 core processor at minimum. You can find cheap 6 cores from both AMD and Intel, maybe something like AMD's Ryzen 2600 or 3600, or Intel's i5 9400. Going for a 4 core processor in 2020 if you plan on playing any modern titles for the years to come is basically shooting yourself in the foot. If you only play older titles it might not matter but if not definitely get a 6 core.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13273432
You may need to deselect compatibly filter at the top like so:
The 8700k is Coffeelake, you need to look at Skylake (6th gen) and Kabylake (7th gen)
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274024
Just get a 300 series motherboard and your problem will be fixed.
The heat sink or the fan? Hope not the heat sink.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274194
2 minutes ago, milk carton said:
MSI MPG Z390 Gaming Plus LGA1151 wont this one work?
It will work for your CPU but take some measurements and make sure it will fit in your case.
System specs below
PSU: Corsair CX650M
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274217
I'd get a cheap 300 series motherboard and keep the i3-9100f since:
1. The 9100f benches better than most cheaper 6th and 7th gen CPUs
2. A low end 300 series motherboard is cheaper new, than what most i5 6th and 7th gen chips are going for even on ebay.
3. Having a 300 series motherboard gives a much better path for upgrading to a better 8th or 9th gen CPU in the future.
For example, $75 bucks new, with USB-C https://www.newegg.com/p/N82E16813157864
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274219
13 minutes ago, milk carton said:
Can I just get a MSI MPG Z390 Gaming Plus LGA1151?
Yes that will work with your i3-9100f, you don't necessarily need that high end of a board but up to you.
I recommend using PCPartPicker to verify that all your components are compatible.
https://pcpartpicker.com/list/
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274227
I know it's just an i3, and it doesnt sound like I have a very good build, but the i3 9100f has outstanding performance for the price, I'm trying to not need to update these components for a while, so I might as well spend a few dollars on the mobo.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274253
Keep in mind that the 10th generation intel CPUs that are rumored to launch later this year will be using a new socket and chipset. So no matter how much money you spend on a 300 series motherboard now, you will be limited to a 9th gen CPU at the newest, without another motherboard replacement.
https://linustechtips.com/topic/1152354-help-me-please/#findComment-13274259
