Can you guys tell me what cable I need to power this internal RGB fan hub?
Solved by W-L,
7 minutes ago, InjuredSmurf said:The 20MB limit was screwing me up. I think the all in 1 box might be fried. Will rip it apart tomorrow to check the PCB.
Bits I cut out of the video:
Remote not controlling anything
Led strip A only lighting up 2 spots
LED strip B lights up fully but changes colour when I touch it (wierd
Hmm that's odd, hopefully the control box is good, but if it's not those are fairly generic fans and controllers so you may be able to get a replacement without the fans.
