Ethernet Port Dead?
Go to solution Solved by Badeumus,
I unplugged the PSU, let it sit for 10 minutes, and then it randomly started behaving again???
Hello,
I posted here recently about not being able to hold a connection to the internet linked here:
However I have had stuttering exactly like the fTPM bug that Ryzen CPUs have been known to have a year or two ago. Slight stuttering with the mouse/game and slowly ramps up until my PC freezes. I went in and turned off fTPM (security device support) and when I logged back into windows I had no internet connection. I then went back in and reenabled it and still had to internet connection. I did a windows reset and I still have no internet connection. I reset the bios back to defualt config. I have no lights on my ethernet port in the back and when I run the trouble shooter it tells me that it is not plugged in, wire might be broken etc. Drivers were updated like a week ago with driver easy - maybe that was a misstep?
Specs
BIOS B650M Pro RS 2.10
Windows 10 64
Ryzen 5 7600
Kingston FURY Beast 16GB (2x8GB) 5600MT/s DDR5 CL36 RGB Desktop Memory Kit of 2 | Infrared Syncing | AMD Expo | Plug N Play | KF556C36BBEAK2-16
GIGABYTE Gaming OC GeForce RTX 3060 12GB GDDR6 PCI Express 4.0 ATX Video Card GV-N3060GAMING OC-12GD (rev. 2.0) (LHR)
ASRock B650M PRO RS AM5 AMD B650 SATA 6Gb/s Micro ATX Motherboard
CORSAIR RM750e Fully Modular Low-Noise ATX Power Supply - ATX 3.0 & PCIe 5.0 Compliant - 105°C-Rated Capacitors - 80 ...
SAMSUNG 980 PRO SSD 1TB, PCIe 4.0 M.2 2280, Speeds Up-to 7,000MB/s Best for High End Computing, Gaming, and Heavy Duty ...
Smarter people enlighten me please thanks you
https://linustechtips.com/topic/1570369-ethernet-port-dead/
If you dont even see any lights while in bios then your NIC is probably dead. You dont see your network adapter here right?
https://linustechtips.com/topic/1570369-ethernet-port-dead/#findComment-16410141
I am facing the same issue of intermittent activities on one of my ethernet ports as well. If you find a solution to this problem, please inform us with the pertinent troubleshooting information. May peace be with you brother.
Peace be with you. Al-Ḥamdu lillāh ٱلْحَمْدُ لِلَّٰ
https://linustechtips.com/topic/1570369-ethernet-port-dead/#findComment-16410482
