Which one is the best Air cooler with good balance of aesthetics and cooling capability.
Deepcool GameStorm Assassin lll
Cooler Master Ma620m
Be quite dark rock pro 4
Noctua NH-D15
I'm looking for a bang for buck cooler with great looks.
All these coolers costs almost the same, i can't figure out which one is the best for RYZEN.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
The Dark Rock Pro 4 arguably looks better than the regular NH-D15, but Noctua just released the chromax.black so that kind of solves the 'looks' issue. The D15 is just slightly bigger though, if I'm not mistaken. Performance-wise, they should be similar, with maybe the D15 edging the DRP out by just a couple degrees. I'm not too familiar with the other coolers you've listed though unfortunately.
I would also consider a single tower heatsink, as a high-end one will still be more than enough for any Ryzen 3000 chip I would imagine, as long as you don't plan on doing some super heavy overvolting. My suggestions would be the NH-U12S chromax.black or Dark Rock 4, or if you don't mind the looks, the NH-U14S.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT with custom 3D printed AIO mount, X62 | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15
Dark Rock Pro 4 all the way. Its the best looking dual tower cooler out right now. Black NHD15 is strong 2nd place.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
Noctua NH-D15 Chromax Black would be the best performance if you have a case that can fit it in your case.
Dark Rock Pro 4 seems be slightly shorter cooler if you can not fit a D15. I've seen it being sold for less than NH-D-15.
Assassin III fans are not as quiet as Noctua and Dark Rock fans for those coolers from the reviews I have seen.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
Bang for the buck? True Spirit 140 Power, 50 bucks at Amazon. As good or better than D14/15. Add a TY143 to seal the deal. Le Grand Macho RT is just as good as well, and can be run passively.
AMD R9 5900X @ PBO | Thermalright Frozen Edge 360, 5x TL-B12 V2
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact, TL-B14, TY-143
Aesthetic is very subjective,
As I'm looking this particular CM CA620M cooler, even tho it has RGB it looks like a motor bike engine block wich it turns me off instantly ?
It looks agressive and premium. It's nice
Noctua NH-D15
It looks more unassuming than DRP4 and more simple design which aesthetically I like the most among the 3 you mentioned.
But I have a strange feel when I see the NH-U12S Chromax. It looks so much better than any other black air cooler, it even looks better vs NH-U12S with NH-HC2 black cover or vs CM Hyper 212 Evo Black. For my taste those NH-U12S Chromax heatpipes pattern in all black looks aesthetically pleasing.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
What processor are you running? I wouldn't trust a U12S with a 3950X but you'd be fine on most other Ryzens.
At the same price, the NH-D15 would probably be the best all-around option. Where are you shopping / located? Budget?
What cpu, case, and ram are you using?
