Corsair rgb fans problem
Solved by ddennis002,
2 minutes ago, Bizzare said:I can get them all, but it's so expensive, can't I just get the commander pro?
If you get the commander pro you don't need the node pro, BUT you will STILL need the RGB Fan Hub no matter what this is where the RGB wire from the fan goes into.
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning5 -
Xrniu ·
Posted in New Builds and Planning3 -
8
3
