Hello forum,
I currently have a budget of around $420 to upgrade my gpu and cpu. I know this is isn’t much but I am only trying to upgrade my gpu and cpu as I said. Also I am willing to use a used card if that is a better deal. I am trying to play games such as Fortnite. My current thoughts were a 1660 ti and ryzen 5 2600 but I think I should maybe do intel as I am not planning on recording or anything but rather just gaming. The only application that I would have open in the background is discord if that matter. Sorry I am pretty new to all of this and just enjoy playing games. If y’all could help me come up with some better parts in mind that would be great. I saw something on amazon about a founders 1070 for $248 but I don’t know much so I will see what y’all saw about all of this. Thanks for the help in advance .
current specs:
CPU AMD FX 8350
GPU XFX RX 570
I really have $550 but I am saving 130 for the new motherboard and ram
https://linustechtips.com/topic/1135893-best-parts-for-price/
Do you have a decent power supply?
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140629
You can't upgrade your CPU without also upgrading your motherboard and RAM.
  • AMD 3600
  • B450 motherboard
  • 16GB RAM
  • Used 1070Ti
That's what I'd go for.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140644
  • AMD 3600
  • B450 motherboard
  • 16GB RAM
  • Used 1070Ti
Yea I know that was why I reserved some money so I could get the motherboard and ram. Also does all of that fall within my range of $550. I don’t think it is
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140666
20 minutes ago, Gmart10 said:
Hello forum,
current specs:
CPU AMD FX 8350
GPU XFX RX 570
r7 2700=150, comes with game pass and bl3, insane deal
https://www.newegg.com/amd-ryzen-7-2700/p/N82E16819113498?Description=r7 2700&cm_re=r7_2700-_-19-113-498-_-Product
b450 with 2x8gb of ram ~150-200usd total
a 1660 super for 230usd is basically a 1070, no need to buy used, i'd just keep the rx570 for now and wait for next gen.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140669
You can easily find 1070 Tis on eBay for around $200. RAM is about $60, motherboard $80, CPU $190. Seems to fit to me.
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140682
I have heard stuff about 1070tis on eBay for 200 are scams. Isn’t that insanely cheap for a 1070 ti
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140732
No, they're not scams. You just have to buy smart. It's not that cheap for a card that's a couple years old. I've picked up a couple 1070s for $100.
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13140968
I don’t know how to tell if it’s a scam by “buying smart”. I am just worried that I’ll lose out on my money. I would like to get a 1070ti. Do they let me try it out first?
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13141003
No, they don't.
If you aren't willing to learn what to look for, then buy new.
https://linustechtips.com/topic/1135893-best-parts-for-price/#findComment-13141817
