Air cooler, best suited.
Solved by WoodenMarker,
The stock cooler is adequate. I recommend using it first and deciding whether or not to replace it depending on how satisfied you are with the results.
EnricoJ ·
Posted in Peripherals0 -
EnricoJ ·
Mahbub ·
Posted in General Discussion4 -
1
1
