too keep it cooled at stock? sure.
OC? Absolutely not. I mean, you prob can get a very light OC going on it, but pushing the voltages is a no go.
ask me about my homelab
on a personal quest convincing the general public to return to the glory that is 12" laptops.
cheap and easy cable management is my fetish.
3 minutes ago, emosun said:
if you aren't cooling the room in in then no.
what
45 minutes ago, Srijan Verma said:
currently getting like 46-54 max on all cores during games
same with continuous cinebench R20 runs
sound like decent aio, check hwmonitor64 or hwinfo64 and check the package/ or max core temp. Task manager and speccy only shows average.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
There is no harm in increasing the overclock in small steps. Start with locking all cores to turbo speed and do a long test to see your max CPU test. Then you can increase the frequency in steps by 100-200mhz each time. I would excpect that the 120mm AIO is enough for a small overclock to 4,5-4,7ghz but after that you may need a bigger cooler.
Edit...
Testing your temps in games only isn't really a great benchmark.
When I overclocked my 8600K I tested with Prime95 for 8h and Realbench 4h.
You dont really need to test for that long if you only want to check your temps but you need something that pushes you CPU to its limit.
Edited by Boyohan
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: In Win D-Frame   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
Just now, Srijan Verma said:
I dont think task manager shows temps
The temps i told were from hw monitor
check the package temp from hw monitor. and you can overclokc as far as your cpu stays under 85c under load
Edit...
Still stays in the low 50s on prime 95
THIS IS MY SIGNATURE
Good ?
At what speed are you running your CPU atm ?
With those temps you should be able to increase your frequency quite a lot without problems.
Anything below 80-85C is fine.
14 minutes ago, Boyohan said:
Good ?
Currently at stock
