Hey LTT-ers,
I am thinking that a 3600 would be a good CPU to get, but what would a good motherboard be for it?
If i get the 3600, I won't have a lot of budget left for a motherboard.
I don't have a 2nd or 1st gen chip for updating BIOS, so I would need a board that is either OOTB compatible, or has BIOS flashback.
Possible options are
MSI PRO VDH MAX: £65
MSI B450M MORTAR (Max is same price so would go with that)
If I go with the mortar, I would have to drop my current choice of video card (1660 super) for a 580 like card. is it worth it?
Edit: if you have any suggestions for other boards then thats also good.
Edited by Arlodog
Clarity on question
https://linustechtips.com/topic/1131365-motherboard-for-ryzen-5-3600/
how about the MSI B450M Bazooka or the ASRock B450M Pro4, they are both budget friendly but still decent boards. Look for a sticker on the box which says Ryzen 3000 Ready. It may be the same SKU but boards that come out of the factory after ryzen 3rd gen was released mostly come with updated bios
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
Are you planning to overclock? If not you don't necessarily need a mortar. I have the Gaming Plus Max which is a solid board afaik, but it's difficult to recommend stuff to people who are not in your region since prices can vary wildly. Definitely wouldn't drop the budget for the video card, if it comes to that I'd wait a bit and save up so you can afford both the motherboard and the 1660 super.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Thats a good idea, I'll look into it.
1 minute ago, boggy77 said:
if you post your full planned build and budget, we might be able to help reduce the cost enough to get a decent board
I already have storage, case and PSU, so here is the rest of it:
(Budget = £560)
CPU: Ryzen 5 3600 (£175)
Motherboard: -----
Memory: Corsair Vengeance LPX 16 Gigs (3200mhz) (£63)
MSI Ventus XS OC 1660 Super (£220)
Cheap peripherals for  ~ £35
This leaves with ~ £65 for the motherboard
(Budget = £560)
Motherboard: -----
could probably save a bit switching to a 2600 over a 3600 as that would lower the cost there andd wouldnt bottleneck a 1660 much if not at all (to my knowledge)
or you could go this way as a cheap mouse and keyboard wont be £35 just make sure it has a sticker saying 3rd gen ready
8 hours ago, Arlodog said:
Awesome, thank you!
i compared a gtx 1070 to a 1660 super like you wanted, and i found that it is 20ish pounds cheaper buying off ebay than buying new. but then again certain people dont like buying used hardware, i dont see an issue especially off of ebay when their buyer protection is a1
gtx 1070 and 1660 super comparison link:
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1660S-Super-vs-Nvidia-GTX-1070/4056vs3609
Edited by roadratt
i missed a pretty important word LOL "off of ebay"
MSI B450-A Pro has been real good for me. Has flashback button.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Power phases and vrm cooling is pretty good too.
Black Knight-
Daughter's Rig;
