CM Fans Compatible with Corsair Node Pro?
I have a CM ML240R coming, and I just bought a triple pack of Corsair LL120s. Can I plug the CM fans from my AIO into the Corsair Node pro and control them all with icue?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1131352-cm-fans-compatible-with-corsair-node-pro/
Nope.
Corsair only works with Corsair stuff.
17 minutes ago, minibois said:
Nope.
That fuckin sucks. I just bought the LL120s because Newegg is going to take a month to deliver my 3 case fans.
Would it be worth the hassle to use two different RGB controllers if I hardly ever plan on changing colours? Or should I just return the LL120s and wait for my CM case fans?
EDIT: I’ll need iCue anyways for my keyboard btw
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
If you're gonna set it to a static color, it doesn't matter much to have multiple controllers.
The only annoying thing would be setting it to the same exact color.
The programs and LEDs might not fully match.
Yeah I’m just going for a white light to illuminate the build. So i don’t think it’ll be an issue
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
