Quick disconnect fittings ?
Go to solution Solved by IntMD,
On 12/5/2019 at 2:46 AM, JustSum said:
snip
https://modmymods.com/fittings/quick-disconnect-fittings.html
I'm assuming you are in the US so, the above has some that are 3/8 ID apparently. I imagine newegg etc. have some too. If you get something that just has 'Male' in the name for example, you will still need a female one for the other side of the hose.
The 'Alphacool Eiszapfen HF Quick Release Connector Kit G3/8 Inner Thread - Incl. G1/4 Reducer - Chrome (17371)' that's on there looks like it probably has everything you would need from what I can see there.
They might well be cheaper somewhere else as I haven't looked other than a quick google, but from what I remember when EK brought the ones on their prebuilt Predators they certainly never used to be particularly cheap.
Ok so i want to add 4 quick disconnect 2 for the cpu and 2 for the gpu .
I'm new to the quick disconnect but i just think it would make life much easier.
I don't even know the name of the fittings sizes,or if the quick disconnect comes with everything i'll need.
I've a xspc cpu water block and a 1080 ti gigabyte with water block hoping 1 360 rad is enough I do have another 240 rad but just dont feel like adding it to the loop atm.
Tubes i use are primoflex advance lrt 3/8in x5/8in
This is what i want to do but not sure what to buy.
So i was wondering what would i need?
https://linustechtips.com/topic/1131217-quick-disconnect-fittings/
you would 4 pairs. I know a long time ago @LinusTech imported some for NCIX but  I've got no idea what they were.
I'd add in your extra rad only 360 is a little low for a CPU+GPU loop
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
snip
thank you so much.
