Help! Samsung 970 evo (M.2) hiding other drives
Go to solution Solved by Vishera,
2 minutes ago, Jurrunio said:
Check in the users manual whether using the M.2 slot disables SATA ports. I think they do
In some cases they indeed disable some ports (ports 5 and 6),
OP should move the SATA drive to a different port.
When I install my Samsung 970 evo (M.2), my SATA drive is no longer recognized. Even when I go into my bios under boot drives, all it shows is the 970 evo. When I remove it and go into bios, my SATA drives show up again. Also when I boot with 970 evo removed, it boots using my other drive like normal. Finally, I had to install windows on the 970 evo because without it, trying to boot would take me to a black screen telling me to select a boot drive and reboot or something.I don't understand why. I just want to use my 970 evo as a supplementary drive. I'm running windows 10. Here is my hardware:
Ryzen 5 3600x
Patriot viper 3200mhz (16gb)
Asus B450 Prime mb
Vega 64
Gigabyte 500gb SSD (SATA)
EVGA 850W Gold psu
https://linustechtips.com/topic/1130495-help-samsung-970-evo-m2-hiding-other-drives/
Desktop benching:
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
