I am planning to build a pc for the internet only.
I am using my old i7 6700k with a GTX 1080. The motherboard is a ASUS Hero IX.
I have all the parts except a CPU cooler.
I usually use Noctua NH-D15 for my gaming builds but this CPU won't be overclocked.
My budget is around $50 US.
Thanks in advance of any help you can give.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/
1 minute ago, GenericFanboy said:
I mean, are you gonna sell your 1080? For just internet you dont really need it. Could buy a nice cooler with that money.
At this point in time I am not selling any cards.
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13075894
i7 6700K at stock should be relatively easy to cool, especially if you undervolt it slightly.
Arctic Freezer 34? Can be had for about $30-$40. I expect that would be able to handle a stock 6700K without any issues. I have one in the closet that I bought as a backup for my current cooler, but I haven't had to use it yet so it's just sat there for a few months unused. :D
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13075899
Thanks
I had a Noctua NH-D15 as a spare but I gave it to my Son because his RGB ram would not hit under his DARK ROCK PRO.
The only thing I have lying around is old Intel stuff but I would have to be crazy to use that.
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13075919
If you're literally just browsing with the system, the stock cooler is fine with the cpu undervolted.
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13077035
It originally had a Intel tower cooler on it but the fins are dust magnets and even a fine layer would cause a throttle.
I ended up ordering a Noctua NH-U14S. It uses a 140mm fan and I have one as a spare so if later on I add a more demanding CPU I can add more cooling to it.
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13077120
To correct, U14S uses A15, 150mm fan with 120mm mounting holes. So if you want to mount another fan with included clips, it needs to have 120mm mounting holes. But on stock clocks it's already overkill cooler so probably no need for such.
(running U14S since 2013).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13078187
The spare is an A15.
This computer will basically be my 2016 gaming build and even though I don't plan to use it for gaming I will use it for comparison testing. Like a dummy I forgot to save the folder that had all the screenshots of the bench tests I did with it when upgrading to a i7 8086k and Windows 10.
I like to have this sort of info since the comments I make on forums about hardware are from my experience with it.
It will also eventually become my 2018 build since it may get a i7 8086k along with a RTX 2080 ti in the future.
So hopefully the U14S will handle my old gaming hardware for years to come.
https://linustechtips.com/topic/1127439-cooler-for-a-i7-6700k/#findComment-13079001
