Budget DAC/AMP vs B450 Pro 4 Audio
Dreadnought
My motherboard is B450 Pro 4 (Realtek ALC892 Audio Codec) and my headphone is Phillips SHP9500. Is it worth it getting a budget unit like FiiO K1, SMSL B1, SMSL M2, or Topping NX4? Will the difference be noticeable over the stock motherboard audio?
With that headphone? Honestly stick with your mobo  as it should be good enough and those budget DACs are only good imo if you are running a laptop with a crap output or a old pc
Ok
