I did some video editing and I've noticed package node 0 in hwmonitor said 92C max afterwards,  CPU was 64C.
So what is this and is 92C too high?
CPU: 3600
Mobo: MSI B350M
Ram: 16GB 3200 LPX
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
package node 0 sounds like the tctl temp. You should only have to pay attention to tdie or what the lower temp is reporting.
But lets wait for a few more opinions before you take what I said as true.
Ok,  but that doesn't really tell me anything... Would 92C be high or still normal under heavy load, regardless of what it is exactly?
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
The thing is AMD built in a temp offset (why, I don't know) that reports the real temp+a number. I don't know what that number is for Ryzen 3rd Gen.
The tdie (lower temp) is suppose to be the real temperature at the die (the silicon on the CPU). The tctl is suppose to be the tdie+the offset (so you get a much larger number). I'm assuming package node 0 is the tctl. If your tdie was 92C you would be experiencing serious thermal throttling and your CPU clock would tank.
Oh I see,  yeah that is weird they would do that huh.
So well,  unless we get a better answer I'll suppose you're right then... :)
i don't think there was any throttling either,  the edits went as fast as expected.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
