they said, Air is better. im a noob as well. based on what they said, there are air coolers that are actually better than water coolers.  watercoolers also have shorter life span than air coolers (broken pump = broken AIO)
Pros of air
-cheaper
-looks cooler(depending on the aesthetics)
-has a longer lifespan(practically immortal unless you threw it around LOL)
Cons of air
-sometimes, if its too large, it can block the ram or even not fit in the case
-(my personal fear) if the heatsink is too heavy it might fall off if not secured properly and practically destroy the gpu.
Pros of water cooling
-Easier to install
-can fit in most cases (depending on the size of the AIO)
-can cool better(depending on the size of the radiator again)
cons of water cooling
-can leak(oof)
-radiator can be hard to fit if the case does not support the mounting
-E X P E N S I V E
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13032883
16 hours ago, LinusFan132 said:
So as I am a newbie in the PC area (well not in my school), what are the pros and cons of water and air cooling?
Air coolers are basically set it and forget it unless a fan dies.  There really are no parts of an air cooler that will die unless physical damage is involved.
With an AIO you have the possibility of a leak, a pump dying, or a fan failing.  The chances of a leak or dead pump are admittedly very small if you buy a reputable brand, but still non-zero.
Most people pick based on aesthetics or case size limitation (since the top end air coolers can be very large).  I personally like air for it's simplicity, but when I finally getting around to upgrading my gaming rig I may try an AIO.  But that's more since I want to switch it over to a sorta small form factor build where a large air cooler might not fit.
I would not recommend custom loop water cooling as a first time system builder.  It will perform better than any air cooler, but the cost, complexity, and risk go WAY up.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13034508
-Easier to install
I'd argue it's the opposite. There are plenty of difficult installations on either side but a good air cooler installation is much easier than a good liquid cooling installation. Any of Noctua's coolers are a great example that a liquid installation would struggle to compete with.
@LinusFan132 If you would like cooler recommendations, tell us your specs and what you're looking for in a cooler.
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13036898
Price:
AIO's generally cost more. Anywhere from (USD)$45 - $200
Air coolers are cheaper as a rule. You can get a very good cooler for $60. Anywhere from $25 - $110
Compatibility:
Some air coolers can run into tall ram. In some rare scenarios block the top PCIE slot. Some are tall and require a deep case.
AIO's come in 120mm, 240mm, 280mm, 360mm, (rare) 420mm
Most cases can fit a 120, 240 or 280. They don't block ram or PCIE.
Either way you have to check to see if your motherboard and case are compatible with your choice.
Performance:
Air coolers reach equilibrium and dissipate faster than water coolers.
AIO's handle temperate spikes better.
A few high end air coolers compete with high end AIO's. ex: Noctua D15 competes with something like an NZXT X62.
A 240mm AIO or a mid range air cooler are plenty for most peoples use case in my opinion.
Reliability:
AIO's have a pump that could die, could corrode over time, and can leak.
Failure rates are low but possible. Some have a software to save the CPU if the pump dies. Some companies will cover damage costs from leaks.
Air coolers are as reliable as the fans on them. If a fan dies, the heat sink can passively cool enough to allow your CPU to downclock and protect itself.
Air coolers and their fans are also generally covered under warranty.
TLDR:
Air coolers are generally cheaper and more reliable.
AIO's generally cost more and can have higher cooling potential.
Find one you want, see if it's compatible with your components. Check reviews for warranty experiences, noise and reliability.
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13038726
2 minutes ago, StarsMars said:
-snip-
To add on to that for open loop/custom liquid cooling:
Price:
Unless you go super cheap AliExpress style like @Tristerin, pretty much always more expensive than even the most costly AIOs. My loop was all brand name stuff so it's around $500-700 or so (you can go a good bit cheaper if you shop around).
Compatibility:
As compatible as you want it, you're picking every component yourself so you can build for pretty much any case and hardware (there's even watercooling kits for the Raspberry Pi).
Performance:
If built right, as good as it gets without going exotic (Chillers, LN2, other stuff like that). If you're limited by your case or something, then still slightly above good air coolers/AIOs most of the time, but most of the difference is on the GPU (GPUs take very well to water). Really depends on budget and what case you're running.
Reliability:
Pretty damn reliable if you go for something like EK-ZMT (rubber tubing) with stubbies and zip ties. Never had a single leak with that setup, blocks are dependable af, and D5 pumps just kinda pump forever, I've never heard of reliability issues with them. So long as you don't mix metals and run good coolants to avoid blockages it's basically just flushing/refilling the loop maybe yearly, depending on the size of your res, maybe a couple top-ups too.
If you go with hardline then it'll be less reliable but still if built right they shouldn't have any issues.
TLDR:
Expensive, but you have full control. You decide how it looks, you decide what you'll stuff in your rig, you decide how it performs, you decide how reliable it is.
Like other peeps said I wouldn't recommend it for a first time builder, I just wanted to give a perspective on the third option.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13038739
@Zando Bob I cant get enough of them $12 aluminum radiators!  I just bought some new antifreeze to try in my next loop, twice as expensive and I need to do more research but Im pretty sure its PETG safe from the chemical sheet I was looking - its G05 stuff, goes in the high end cars etc and should make hardline loops cheap too!
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1121954-air-or-water/#findComment-13038812
