[HTML & CSS] move margin, keep text same place
Moved to programming.
From what you've shown, you can solve it by reducing the left value in css, and adding padding-left. For example,
#toptext { width: 1665px; position: absolute; top: -5px; font-size: 25px; background-color: #f1f1f1; left: 219px; padding-left: 15px; }
(you will need to change the amount that they are changed by to suit your spacing). Padding is included in the background, and you can do padding-top, -bottom, -left and -right.
However, using position: absolute like that is not a good idea. I would strongly recommend that you use a layout approach that will put things next to each other by default. The most up-to-date way to do that would be to use flex boxes, although they are a relatively advanced CSS concept and it sounds like you are just starting out. For some reason I'm struggling to come up with a beginner-friendly way of doing sidebars in CSS off the top of my head, but if you search around there should be examples.
