Pc disconnecting from monitor
I built my new pc a couple of days ago and it started disconnecting from my monitor when I turn it on and leave it for about 30 minutes to an hour and in games its 10-15 minutes. My GPU idle temps are 40-50C and when I'm playing games its about 70-80C I checked my PSU it seems fine and my MOBO is also fine. I am using a HDMI (with 240hz monitor) because I don't have a DP just yet its coming later tomorrow. Its been happening for about 10 Hours now I'd say.
Specs are:
Zotac 1080 AMP edition
Ryzen 2700x
B450 Tomahawk
16GB DDR4 Ram
Alienware AW2518HF
Windows 10 PRO
Edited by ArtefytGee
you left out what monitor you have lol
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Download the newest drivers from Nvidia, remove the old drivers using display driver uninstaller, install the new drivers. If that doesn’t work try using another port on the monitor and your GPU. Double check the sleep settings in Windows and on your monitor. Some monitors have their own sleep state setting. If all of that fails and the DP cable yields the same problem try reseating your GPU in the PCI slot. Other than that you may need to RMA your card.
A Alienware AW2518HF
Will do! Thank you for the reply
Sure, post back with an update.
I will update tomorrow when I get the display port.
So, I lowered my Hz on my monitor and changed the ports I'm  pretty sure its fixed.
For 240hz @1080p HDMI 2.0 is required. If you were using an old cable or the one provided with the monitor was of poor quality that could explain the issue.
I am using the one that Dell provided when I ordered my monitor. I thought you needed a 1.2 DP for 240hz 1080p?
It seems to only be happening on Fortnite every other games are fine. I can'y play duos or squads.
