Air VS AIO cooling INDIA
Solved by WoodenMarker,
5 hours ago, Poras said:Case - Cooler master masterbox mb250
I'm guessing you meant MB520?
The H45 would probably be the best performer. https://www.vedantcomputers.com/products/cpu-cooler/corsair-hydro-series-h45
Check with the seller to make sure it's updated with the AM4 mounting hardware or you can get it from Corsair.
If they don't, there's another listing on Amazon from Corsair that's likely to have updated mounted hardware: https://www.amazon.in/Corsair-Cooling-Hydro-H45-Black/dp/B01FSMWFQG/ref=sr_1_3?keywords=corsair+h45&qid=1571755585&s=computers&sr=1-3#customerReviews
