Upgrading to a 5700XT, but I need replacement power cables...
Hi everyone,
Long time watcher of LTT here (7 years strong!), with my first post on the forum.
I have a Corsair CX600M PSU unit. My old GTX 760 broke a while back, so I took out the cable (modular unit) to reduce cable congestion whilst I had no GPU. In typical fashion, I've completely lost it however!
I'll be getting a new Red Devil 5700XT on Thursday, but I am having trouble confidently deciding on a replacement power cable here.
Does anyone have experience with this PSU? Will a 6pin to 6+8 pin Y split cable work, or do I need two separate 6 pin to 6 pin connectors?
Thanks in advance guys!
I've bought replacement power cables for an EVGA unit before.
i don't think you'll need two seperate cables, but make sure that whatever cables you get are advertised or branded to match with you PSU or the series that your PSU is in. Sometimes inter-brand compatibility is and issue and sometimes not all from the same brand are compatible.
14 minutes ago, BloodVyper said:
Hi everyone,
There are a couple Corsair folks on the forums that can help...
@Corsair Nick being the most active I think.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
i mean... with the cost of replacement cables, i'd just get a new psu... which i would advice in general with a 5700xt, that psu and that age
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
Thanks guys. The PSU was only bought a year or so ago, so it should be okay for a little while yet!
@Corsair Nick Thanks for the link, I'll take a look!
@Corsair Nick
I just placed an order through the Corsair site. Do you have any idea how long shipping may take? I chose standard, rather than express.
Order Number is 4000126265
7 minutes ago, BloodVyper said:
@Corsair Nick
In all honesty I also think you really should have bought a new PSU altogether, the 5700XT is a bit power hungry and a high current video card which you're pairing with a low end old Power Supply with outdated topology... it is really not a smart pairing.
Personal Desktop":
Luna, the temporary Desktop:
Is it hungrier and higher current than the 980 Ti? I ran one of those off a CX450M (still have it btw, it was the first PSU I ever bought and it's worked fine since about 2017 when I got it) with no issue, the CXM series is a pretty solid budget platform (I think the new CXs are a bit better though?).
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Grey Label CX are worlds better than Green Label CX.
However one thing to note is that the Grey label CXM IS NOT the same power supply as the Grey Label CX.
Even the Grey Label CXM uses considerably outdated topolgy and is actually a bit of a bad pick even for budget systems for today's standards.
Just because it worked and to some people it never gave them any issue it doesn't change there's better stuff on the market sometimes even for the same price...
I'd point out @jonnyGURU for this subject as no one would be more reliable to go through the differences on the many CX/CXM units out there but I think he hasn't been around the forum as much any more.
Personal Desktop":
I did a calculation using OuterVision's wattage requirements calculator and I have a good 150W of headroom. I've run a GTX 970 on it for a short while, never had any issues.
I will upgrade it eventually, the deal on the 5700XT was simply too good to resist!
In all honesty, I'm going to end up playing Project Hospital, Rimworld and Cities Skylines on it, rather than the latest AAA titles for now. Only a 60hz 1080p monitor too, so the card shouldn't be utilized much.
Yeah I knew the green label CXs were bad, I was saying new CX > CXM, though the CXM isn't horribly horrible either. Think the CXM is bad enough that it warrants an upgrade if you already own the PSU though?
that said, the M12II is known for being very outdated and bad but I had no issues with mine, so your point that it working =/= it's always good is true. I still have it because I haven't heard much good about them (I bought it as a nooby lad without too much research) and I haven't trusted it enough since to put it in a rig to sell, lol.
EDIT: Also note, my CX450M is a grey label, I don't know the difference between the grey and green label CXMs.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
The Green Label yes, if it was the Grey Label then no.
Like yours a Grey Label which is fine, but OP's a Green Label.
Going through an old thread here at LTT we have this explanation:
The 430, 500, and 600 watt model of the CXv3 / M models (the one with the Green logo) are DSA-III based unit from CWT. They are based on an old group regulated design. The 750w and 850w models are CWT PUQ-B which utilized DC-DC for the minor rails which will yield better voltage stability than the lower wattage counterpart. All of which are warrant for 3 years and are rated for 30C.
The new gray labeled 450, 550, 650 models are a custom design from CWT (essentially a cost down version of the RM 450-650) are DC-DC regulated, 40C rated, black cables, and a 5 year warranty. The 750 and 850 is still based on the same platform before but has a higher rated bridge rectifier along with all of the changes mentioned with the lower wattage models
Just the fact it went from Group Regulation to DC-DC already is a big plus on the matters of reliability and safety.
@BloodVyper Wattage alone is a meaningless factor, this is a "at your own risk" sorta thing from here.
Personal Desktop":
  Reveal hidden contents
Can you recommended any good value PSU's around the 750W range?
The TX750M usually isn't too much, and it's a damn good unit AFAIK.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
You don't really need 750W, 550W should be plenty.
If you would like some alternative how about give us a budget and your country of origin? with tools like PCPP it's pretty easy to find a good pick.
The TXM (2017) stated above is a very good line up indeed.
Personal Desktop":
I'm in the UK, so around £100 seems like a good balance between quality and price.
I do want to leave some headroom. I'm going to be moving from an i5 3570k over to a Ryzen 3000 based system over the next month or so. I'm starting off with the GPU, since I've been stuck with the integrated HD4000 for the past year or so, and the i5 still performs decently in most titles.
Oh with a budget of 100 pounds it's really easy to find high end very reliable units, this was a piece of cake [:
650W is enough for whatever computer you possibly wanna put together, for your reference my very power hungry i9 9900K with a TITAN V is running happy on a 650W.
So here are 2 perfectly comparable, on the same level of performance, reliability, low noise, safe units you can consider, it's literally pick whichever you like the looks more:
https://uk.pcpartpicker.com/product/2HbwrH/corsair-rmx-2018-650w-80-gold-certified-fully-modular-atx-power-supply-cp-9020178-na
https://uk.pcpartpicker.com/product/Rj22FT/be-quiet-straight-power-11-650w-80-gold-certified-fully-modular-atx-power-supply-bn282
Cheers!
Personal Desktop":
Thanks for the recommendation @Zando Bob
You're welcome! I've used one in a rig for a friend, and though we've already established it working for me =/= good quality, I can confirm they're damn quiet (this one drives an i7 6700K and R9 290X on a custom loop). This one has only had a single clean since December 2017 as well, and every time I've seen the rig it's running quiet af and everything is in perfect working order.
Can confirm, my X5670 at 1.45v on the vcore and 4.54Ghz (high voltage for that, but I was trying to get 4.74 stable at the time) with a Gaming X 1080 Ti at max power target pulled up to 553W in synthetic tests according to my RMi.
That said, headroom is always nice, and I'm not one to talk on reasonable wattages. Run an RM1000i in my main rig, 1000W G3 in my folding rig (low power Xeon, a 1660 Ti, and a 1050 Ti), and the 1600W T2 that was powering that rig now awaits the unveiling of my SR-2. Oh how far I've come from the days of my actually reasonable 450W and 550W PSUs, lmao.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
Cheers!
and for reference, what if we dropped that budget down to £50-£60?
I have some lovely memories, age 12 of 13 (Year 2012) when I got my first gaming PC, relating to the power supply:
Athlon II X3 455 triple core processor
8gb ram
GTX 570
and... a CiT 500 watt PSU.
Installed my CD of assassin's creed brotherhood, it ran just fine for an hour, before the power supply blew smoke billowing into the air around the case.
Luckily nothing died, but that was anxiety inducing to experience!
Looking back, I don't know whether I'm more disappointed in choosing a tri-core CPU or that god awful power supply...
Then we get quite limited, looking through all the available units on this price range the only thing I could recommend is a 4 pounds more expensive TX550M:
https://uk.pcpartpicker.com/product/dDH48d/corsair-txm-gold-550w-80-gold-certified-semi-modular-atx-power-supply-cp-9020133-na
Oh look what a nice coincidence, it is the TXM we were talking earlier [:
Anything below this (cheaper) already gets on the "you're compromising too much" category, if you want something to last then it wouldn't be a good idea.
Personal Desktop":
Ooooooof. According to a recent interview with the aforementioned Jonny Guru though, PSUs often blow on the AC side and the damage never travels over to the DC side, or something like that. Recommend watching it just to get some good general info on PSUs, I only half payed attention while at work so I should watch it through again sometime.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
I'm more surprised the motherboard survived.
An ECS MCP78PVM... horrible, nasty, cheap POS that was!
I was clearly too focused on maximizing the GPU horsepower at the time, and completely cheaped out on everything else lol.
I took a look, I think meeting in the middle with the TXM650 is the sweet spot for me.
Thanks for the help @Princess Luna!!!
