[Solved] PHANTEKS ENTHOO PRIMO VS COOLER MASTER H500P MESH?
Solved by Detective,
On 10/14/2019 at 3:51 PM, jj9987 said:I personally wouldn't pay extra just because the cheaper case is too big (as long as it is not ridiculously big/heavy). If you like the case, keep it.
Thanks for sharing your thoughts, makes sense.
On 10/14/2019 at 3:55 PM, Vishera said:H500P MESH has better airflow.
Yep, you're right, but I am still not sure if I should cancel my order & go with H500P!
EDIT: In the end, I went with the PHANTEKS ENTHOO PRIMO, it's super big but I am happy with it.
