Lian Li O11D doesn’t fit my GPU?
Gauzl
I’m using the Lian Li O11D and I’m doing a custom water loop with the ASUS strix 2080ti with the EK waterblock and the waterblock comes in contact with the side panel, anyone else have this issue and/or have any suggestions?
Your GPU can only be 159mm "tall". Lian Li actually has an EK chart where you can see which fit natively, and which need a Vertical GPU riser to fi.
http://www.lian-li.com/air-gpu-guidance-list/
o11-COMPATIBILITY-02
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
