My first build after I felt my AMD FX 8350 wasn´t doing it for me!
Just saw the youtube video "Our Smallest Gaming PC Build EVER!" on LTT channel so I had the urge to join the "micro build club"
November 2018 I decided to get a project finished that I started half a year earlier.
Since I had given my own PC with AMD FX 8350, GTX 1050 ti and 16Gb of DDR3 1600mhz to my oldest son I decided that papa needs a computer of his own.
I had bought a cheap AMD Phenom X2 case in a small pc format and came across a Mini ITX motherboard for a good value of cost that I saw fit.
Trouble was that the original 250w PSU was not sure to handle what I had in mind.
But I decided to try it out with the new MB and RAM I just got.
So I was pretty proud to start up my Ryzen 5 1600x  with my old GTX 1050 ti and find out it was working.
But sometimes I felt it was struggling.
So... In december 2018 I had my new setup at home and was ready to get my gaming refreshed and be the gamer I was ment to be. ?
I play all my games on high/ultra 1920x1080 and games include Destiny 2, Overwatch, Diablo III, Sniper Ghost Warrior 3, Rise/Shadow of theTomb Raider (actually in 3d on my Benq w1300 beamer) aso....
I didn´t document the build but here is the picture of the "little offspring" and the specs for it.
SPECS
Case        Packard Bell Imedia s1300
MB          BIOSTAR RACING X370GTN mini-ITX
PSU         SilverStone SFX Series SX600-G
CPU         AMD Ryzen 5 1600x w Scythe Big Shuriken 3
GPU         EVGA GeForce GTX 980 Ti 6GB ACX 2.0+ SC+
RAM        Corsair 8GB (1x8GB) DDR4 2400MHz CL16 Value Select
Optical     Generic DVD-RW
SSD        Intenso Top M.2 2280 SSD SATA III 128GB
HDD       Seagate BarraCuda 2TB 7200rpm 64MB
The case meassures:
Height  31cm (12.2")
Width   18.4cm (7 1/4")
Dept    31cm (12.2")
20191013_000427.thumb.jpg.695dc4af09c5e01509ddce574eeef243.jpg20191013_000355.thumb.jpg.02cf8b896940c435055cc7667683e225.jpg20191013_000332.thumb.jpg.a3804ea76177820f3db06aa3aa62c356.jpg20191013_000802.thumb.jpg.d49b71516eb79d8f37fc681d89f8ac45.jpg20191013_000525.thumb.jpg.23205afc3903a70f20c8da9ee76f1396.jpg20191013_000515.thumb.jpg.8063849b2982b5e2d4bc2be5bf55284d.jpg
Edited by BurgeSWE
not bad! Only thing I'd add on is another 8gb of faster RAM, but if you had to make a choice get faster first since ryzen runs better with faster RAM
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
Get any cheap cl16 3200mhz 32g kit and will be golden. Oc that cpu to 4ghz try to keep stock voltage. Mine does it on stock voltage.
