not really sure what you are asking but there is no problem with just opening the reservoir for a clean
Builds:
hey Bananasplit (cool name btw) all im asking is if i can run water though it or i can open it up clean. But since you said it fine to open up i guess thats waht I'll do.
you should always clean watercooling parts before assembly, dosnt matter if they are new or used.
Builds:
