Caselabs Th10 Project!
mikk63792
Hey guys, and a big HELLO from Denmark!
I've been working on my new rig for a while now.. I sold my TJ11 earlier this year, so i could buy i Caselabs TH10.. So i did..
I'm still missing the last fittings, some fluid and two UN Z2 mounts, so i can mount my pumps, on top of the bottom 480 radiator!
For now, i'm planning to create the entire loop in crystal link! Hope it turns out awesome  ;)
As you can see on some of the first pics, i had it build with aircooling on the cpu, and a spare EVGA GTX570 i had.. Just so i could game a tiny little bit  :P  But enjoy the pics, and drop a comment if you want! I will be ordering the last things, when i get some more $$  :lol:  A complete spec list will be listed below  :)
The full spec list:
Hardware:
Motherboard: Asus Rampage IV Extreme
Cpu: Intel Core i7-3930K
Memory: 4 x 8GB Corsair Dominator 1600Mhz
Graphics Cards: 3 x EVGA GTX680 2GB
SSD's: 1 Intel 520 120GB and 2 Intel 520 240GB
Harddrive's: 4 x 2TB Samsung drives
Psu: Corsair AX1200
Fans & Accesories:
Case fans: 4 Corsair AF120 Quiet Edition's
Radiator fans: 16 Corsair SP120 Performance Edition's
Fancontroller: Lamptron FC Touch
Bluray burner: Lite-On something
Watercooling:
Cpu: EK-Supremacy - Nickel
Motherboard: EK-FB KIT RE4 - Nickel CSQ
Graphics Cards: 3 x EK-FC680 GTX+ - Nickel
Memory: 2 x EK-RAM Monarch X4 - Nickel CSQ
Pumps: 2 x Swiftech MCP655
Pump Top: Bitspower Dual D5 Mod Top
Reservoir: Bitspower Dual / Single D5 Top Upgrade Kit 150
Fittings: Bitspower Black Sparkle all the way baby!
Hose: Crystal Link all the way!
Radiators: 2 x Alphacool NexXxoS Monsta 480
post-16182-0-49350700-1367018393_thumb.j
post-16182-0-09234400-1367018403_thumb.j
post-16182-0-16791600-1367018409_thumb.j
post-16182-0-23790400-1367018421_thumb.j
post-16182-0-06704900-1367018428_thumb.j
post-16182-0-03754400-1367018436_thumb.j
post-16182-0-94767600-1367018443_thumb.j
post-16182-0-16788800-1367018453_thumb.j
post-16182-0-61704300-1367018460_thumb.j
post-16182-0-98624800-1367018467_thumb.j
post-16182-0-61797800-1367018506_thumb.j
post-16182-0-69399000-1367018513_thumb.j
post-16182-0-07828000-1367018522_thumb.j
post-16182-0-99941800-1367018528_thumb.j
post-16182-0-14829700-1367018536_thumb.j
post-16182-0-99306400-1367018561_thumb.j
post-16182-0-82406900-1367018578_thumb.j
post-16182-0-99273300-1367018586_thumb.j
post-16182-0-85956200-1367018593_thumb.j
post-16182-0-23156300-1367018600_thumb.j
post-16182-0-23765600-1367018613_thumb.j
post-16182-0-11792100-1367018623_thumb.j
post-16182-0-55805100-1367018631_thumb.j
post-16182-0-93139900-1367018645_thumb.j
post-16182-0-79135800-1367018655_thumb.j
post-16182-0-99529100-1367018664_thumb.j
post-16182-0-06358600-1367018675_thumb.j
post-16182-0-64006700-1367018686_thumb.j
post-16182-0-95896200-1367018695_thumb.j
post-16182-0-94484800-1367018705_thumb.j
post-16182-0-02862000-1367018718_thumb.j
post-16182-0-56776300-1367018729_thumb.j
post-16182-0-96793200-1367018737_thumb.j
post-16182-0-22326000-1367018747_thumb.j
3930K, 32GB Dominator, Rampage IV Extreme, Caselabs TH10, AX1200, 3 680's, Full watercooling!
congratulations to a fellow CaseLabs owner..
look into E22 for your acrylic tubing for long spans.. the 10/12 can mate-up with
bits links..
it's sad that you have brilliant hardware and the case makes it all look sooo small...
good luck with the future of the build.. loks spankin' now!
airdeano
Finish it up quickly, I want to see what the finish thing looks like. Also, it looked so silly without the watercooling stuff on it, like a huge waste of space :P
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
Just... freaking Huge :blink: Good luck if you're going to lan with this case :D . it also looks very good
I7 4770K - @4.5Ghz  |  Be quiet Dark Rock Pro 3  | Asus Maximus VII Ranger Z97  | Kingston Genesis 8GB | Be quiet Power Zone 750w   | Sapphire R9 Fury X |  Sandisk SSD 120Go + WD Green 1TB 7200 rpm | Nzxt Phantom 410
That motherboard is dwarfed xD. Gotta love caselabs' modular design, although I'd be stupid to buy one myself considering the shipping cost :(.
WOW, love the TH10.
but why are you hiding the reservoir and the pumps? they are made to show off :)
lots of EK waterblocks in one place  :o
Love Caselabs
Yes, yes we do :D
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Thanks guys! I've just spend $716 at Performance-PCS.com.. Now, i'm only missing my Z2 mounts and some fluid.. Then i'll be ready!
bits links..
airdeano
Well, i've bought some 12/10mm acrylic tubing here in Denmark.. I got 4 meters i think.. So i will have plenty! But i thought it sounded better with Crystal Link! LOL
I will be doing it, as fast as possible! And yea, the case is freaking HUGE!
No LAN for me with this computer! I will probably build another for that in Caselabs's new Mercury S3!
Haha yea  :D Caselabs is just.. WOW! I payd something like $284 in shipping..
WOW, love the TH10.
TH10 FTW! Because i have my harddrives on the motherboard side.. And there isnt enough space for them at the radiator side.. And yea, gotta love EK!
Love Caselabs
Yup!
A tiny update!
I made a hole for my draining system at the bottom! I will clean up the hole, and maybe put something on to the edge, so i want scratch the fittings! But enjoy! Another update will come, when i get my fittings, and finally, some pictures of the beast running! So hang on guys!
post-16182-0-73787800-1367185057_thumb.j
post-16182-0-28324500-1367185071_thumb.j
post-16182-0-17820900-1367185078_thumb.j
great idea, I was contemplating using a fill port and hard-lining from the rad to the fill port with a
valve and i'd remove a stop cap and substitute a fitting and hose for a drain.. but a hole could work.
that way nothing could accidentally knock off the exterior mounted fittings.
airdeano
Looks cool good job case is a bit big :)
| Contact Information |
My Teamspeak : Austs1.gameservers.com:9334  |  Steam: Iamtictac456  |  My other aliases include Scruffy and Scruffy Biggems :)
is that like a server tower case ?
vary nice looking build BTW
that case makes every peace of hardware look small
Character artist in the Games industry.
Awesome system! You should put mitx system in that case.
Intel i5 3570k | MSI GTX 670 Power Edition/OC SLI | Asus Sabertooth Z77 | Corsair Vengeance LP 16GB | Fractal Design Newton R2 650W | NZXT Switch 810 SE Gun Metal | BenQ 24" XL2420T 120Hz | Corsair K90  | Logitech G500 / Logtitech Performance MX | Sennheiser PC 360 | Asus Xonar DGX | NVIDIA GeForce 3D Vision 2 Wireless Kit
airdeano
I think it looks clean.. You cant see it at all, from above, unless you go down on your knees (Thats what she said)  :P
Thanks man! Nothing is too big! It just gets bigger xD
Someone will probably use it as a server case.. But i dont.. Its my main gaming rig  ;)
Such a monster :o
looking forward for more updates
Yea, she's eaten too much  :(  Update will come, when i get my package from Performance-PCS! And my Z2 mounts were also shipped today!  :D
So true!
I have another computer with a mini ITX motherboard in  ;)
  • 3 weeks later...
Its been a while since i made an update, so i'll post one now..
So, it turns out that my package from Performance-PCs has arrived in Denmark, BUT, Performance-PCs forgot to attach the export document, so i will have to wait another week or 2, before i can get it.. Pretty f****** annoying!
Meanwhile, i got my Z2 mounts from SideWinder Computers, so i could mount my pumps, which is great!
post-16182-0-97235800-1368790223_thumb.j
post-16182-0-69572200-1368790230_thumb.j
post-16182-0-87874700-1368790237_thumb.j
post-16182-0-45324900-1368790245_thumb.j
Looks beast!
did you inspire from the "Singularity Beast II" from the guy on youtube SingularityComputers?
he did very similar idea of mounting the pumps.
Good job mate!
Looks beast!
Good job mate!
You're totally right! I'm a huge fan of him! All of his builds are just PERFECT. And yup, he did the exact same thing with his pumps  ;)
All I could think was how small the motherboard looks in there.
Yea, it feels tiny, but sure isnt  :D
meget flot. Fellow Dane
CPU: I7 4790K GPU: Manli GTX 980 Mobo: Asus Gryphon z97 RAM: kingston Hyper x fury 16GB 1866mhz PSU: EVGA supernova 750W G2 SSD: Samsung 840 evo 500GB HDD: WD Black 3TB Case: Parvum s2.0 Fans: Noiseblocker E-loop 800rpm Cooling: Custom water cooling
looks nice so far :)
En dansker! Wooo  :D Men jeg takker!
sweet build dude
Thanks man!
It gets even better!
