On 9/25/2019 at 8:39 AM, SirSpideySenses said:
EVGA 500w 100-W1-0500
On 9/25/2019 at 9:45 AM, 5x5 said:
The W series are horrible.
I own the same PSU, and I have no problems running an overclocked GTX 970. I believe it would be fine with a GTX 1070 but, I don't know about a 1070ti and a 7700k, that might be pushing limit. 650+ watt should be safe.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
On 9/25/2019 at 5:37 AM, seon123 said:
Depends on the 500W PSU in question. Why would you not tell us which model it is...?
On 9/25/2019 at 5:39 AM, SirSpideySenses said:
Sorry i believe it is a  EVGA 500w 100-W1-0500
That's why.
Lucky you.
Luck you. The W1 is not good at all. It's arguably worse than even the S12II. The issue isn't wattage, it's everything else
It is better than the POS that it replaced, it was $40 new and I installed it in a very cheap oem acer but, for the setup @SirSpideySenses is going for, maybe the BR or BQ series or higher end is a better option.
BTW @5x5 you have not explained why the W1 is not good, and of course the W1 is not as good as the S12ll, they are different tier levels.
System specs below
PSU: Corsair CX650M
It should be able to power it, but I'd still recommend replacing it with a decent PSU.
As we all know, anecdotes trump data.
Odds are that you paid $40 to downgrade your PSU. At $40, that's at least $39 more than it's worth.
