Ti 83 Plus for AP Calculus AB?
Go to solution Solved by dalekphalm,
18 hours ago, Shreyas1 said:
Does anyone know if a TI 83 Plus will work for AP Calculus AB? Has anyone used one on the test? I saw the college board says that the 83 plus has all the necessary functions but does anyone know whether I should actually use it? Thanks!
Your school (or specifically the class) will likely have a recommended calculator to use. You should just use that one.
Why? Because if you're having issues doing something, the prof is going to be far more familiar with the recommended calculator than other models.
Which calculator do they recommend? If the TI 83 Plus is on the list, then use it. Or use a different one that's on the list.
https://linustechtips.com/topic/1104485-ti-83-plus-for-ap-calculus-ab/
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
In my personal experience, professors will say Ti-83, Ti-83 Plus, Ti-84, Ti-84 Plus. Some professors may specifically mention the updated colour versions as well, but let me tell you:
Professors do not EXPECT you to use a Ti-83, most times. The 83 is an out of date calculator, and their lessons will likely revolve around updated versions of the 84's firmware. So, if you're wise I would buy an 84 plus and update it (free and easy to do, though it is a little finnicky. I had to try ~4 times on my 84 Plus which was quite old).
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Yeah I'll probably just ask my teacher if it's a good idea then. Thanks!
I'd really recommend taking a look at Casio's lineup. I used an FX-CG10 (PRIZM) calculator throughout high school, and it has worked beautifully. IMO its UI is far superior to TI's, and it is far more intuitive to use than a TI. It also has a color screen, which is absolutely amazing for graphing multiple functions at once. It color codes parentheses, shows fractions in their natural format (super useful for nested fractions). But far and away the most useful function is the ability to go back in your calculation history and change things; from what I remember you can't do that with a ti-83 and you have to retype the entire expression if you make a mistake. The FX-CG50 is (AFAICT) the updated version of the FX-CG10, and is actually cheaper than the ti-83 on amazon right now. Basically, this thing is superior to a TI-84 in every way, and is still significantly cheaper.
Edit: Oh and I was able to play flappy bird, 2048, and minesweeper on my FX-CG10 :P
Edit 2: The speed difference is also hilarious, even to the TI-84 plus CE, which has a processor that is three times faster than the ti-83. I hadn't thought about it before but it could really help on timed tests (like the AP):
Current LTT F@H Rank: 69    Score: 3,457,572,143    Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 3900X w/PBO on
Cooler: Noctua NH-D15
Mobo: Asus X470-F Gaming
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 6.12.4
CPU: Ryzen R7 2700x @ Stock
Cooler: Noctua NH-U9S
Mobo: Asus Prime X470-Pro
RAM: 16GB G-Skill Ripjaws V + 16GB Hyperx Fury Black @ stock
PSU: EVGA G3 850W
SSD: Samsung 980 Pro 1TB NVME, Samsung 970 evo plus 1TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (3x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
